RadioBOSS 7.2 [beta]
So, wouldn’t it be better to add an option to define the estimated time as an approximate number of minutes or hours after generation? Obviously, based on the moment when the generation command is triggered.
Yes, this will be possible as an option, we'll see how to implement this, maybe using the scheduled templates or other approach.
From the Scheduler, I get the same type of result and the problem is identical: some tracks already present in the playlist (the player) are in the playlist file (.m3u8).
I think the playlist tracks aren't being taken into account when generating multiple playlists.
I think you should also check the logs to see if it shows that the playlist tracks were loaded.
oh yeah i realised that it wasnt like that in 7.1
Tag display in the playlist was not changed in this version.
for some reason since yesterday when i have the mic on, music is no longer heard locally at the lowered level set its just simply disabling music. no setting have been changed from how it was a week ago when i was last on air and Mute Monitor sound card is NOT selected only output to encoders nly is so i dont hear myself... theres also a delay from when i turn the mic off to when i start hearing it again
I know there was a similar issue back in build 5
There never was a bug with this, the reasons why a microphone stops working is when a wrong device is selected, or its level in the system is set to zero. Even if you didn't change anything the driver may have been updated and device may stop working because of that. You should check the Logs section to see if there are any error messages regarding Inputs.
If you have assigned a custom color to a playlist tab, this color does not change to the color set for the active playlist when you activate it.
The custom tab color has precedence over the other general settings, that's why it doesn't change.
The Tabs in previous version where much better in my opinion
This tab design was from around 2015, it's time to change it :)
In the mixer, the setting for Main has no effect on the signal to the stream server.
That might be interesting.
Yes, this is by design, it controls audio devices, not resulting output. For this, there's Gain slider in the main player window.
It seems there's a problem with a function that isn't working. When you hover over the slider shown in the image, a "Reset: right click" prompt appears, but when you right-click, nothing happens.
Thank you, we'll check it.
No, I tested it with various music styles and it still has a delay.
We can't reproduce it here, I'm sorry.
The log also displays "0" on the line "Loaded tracks from the playlist window: 0".
I went back to the Scheduler and my "Generate Multiple Playlists" event. I noticed quotation marks at the beginning of the command, whereas there aren't any in the other "Generate a Playlist" events using Playlist Generator:
run "PlaylistGeneratorPro.exe" "-preset=…​
I removed the quotation marks to get this command:
run PlaylistGeneratorPro.exe "-preset=…​
This allows the tracks in the playlist window to be taken into account.
And the line "Loaded tracks from the playlist window:" correctly indicates the number of tracks in the playlist.
The problem to fix: remove the quotation marks when using "Generate Multiple Playlists".
Now that the tracks in the Playlist window are taken into account when "Generate Multiple Playlist," I've discovered other problems that also appear with "Generate a Playlist."
Tracks in the Playlist window, after the currently playing track, are considered to be tracks that will be played at the same time as the "Start Time," and not tracks that will be played according to the schedule displayed in the Playlist window.
And according to the "Maximum number of minutes to check."
Example (with the same Preset):
Preset generation time: 5:50 PM
Start time: 11:30 PM
Number of tracks in the playlist: 13 (6 of which are among the 10 selectable tracks)
Reminder of my Preset settings:
10 tracks can be selected.​
The artist cannot be played within 60 minutes of its last playback.​
Repeat protection with consideration for tracks in the playlist window:​
Maximum number of playlist tracks to check: 15​
Maximum number of minutes to check: 30​
Take into account expected track start time: box checked​
The behavior I expect from the Playlist Generator:
The 13 tracks should start playing in the Playlist window at 5:50 PM.​
From approximately 7:30 PM, all these tracks should be selectable again.​
The "Start Time" is much later: 11:30 PM.​
What's happening:
4 tracks are in the ".m3u8" file. Normally, there should be 6.
Error message in the log:
PlGen Warning: 1 (error while creating a playlist; please see the log for details) preset: "Test2026_1980"​
And in the Playlist Generator log, the following messages are displayed:
Error: No suitable track found (rule: dayparting). Category: "1980_15h"​
! Interrupted to prevent endless loop [global]​
> 20 errors.​
Total time spent: 00:01​
Completed. Playlist duration: 15:44​
The playlist duration is incorrect: 15:44 instead of 20 minutes (minimum).
The ".m3u8" file only contains 4 tracks instead of the usual 6.
My conclusion: The tracks in the Playlist window are correctly registered.
But not at the right time: they are registered as if they were going to be played at 11:30 PM.
Further tests #01
This time, I only modified one setting in Playlist Generator:
  • Maximum number of playlist tracks to check: 30
  • Maximum number of minutes to check: 90
Number of tracks in the playlist window: 28
Playlist duration: 94 minutes.
The 6 selectable tracks are played at the beginning of the playlist window.
Start Time: 11:30 PM
Result: no errors.
Everything seems correct.
Further tests#02
This time, the Start Time is 6:15 PM.
Result: no errors.
And this time, it's not normal. The 6 selectable tracks in the Playlist window will play between 5:50 PM and 6:10 PM.
And they cannot be played within the next 60 minutes according to the rule against repetition.
At least two of them are selected even though they will play within 5 to 25 minutes.
My conclusion: Regardless of the "Start Time" setting, the entire 90-minute Playlist window is counted.
The Start Time setting is not used for the "Generate a Playlist" and "Generate Multiple Playlist" events.
These behaviors/results are not good for me.
What would be desirable:
  • Take into account the actual scheduled playback time of the track in the playlist window;
  • Take into account the "Start Time".
This will allow for proper handling of the repeat protection.
Manual "Generate" Button (Playlist Generator)
When using the manual "Generate" button in the Playlist Generator, it does not support Start Time, meaning Dayparting and same-time repeat protection will not work.
This is what you explained to me.
Can you integrate Start Time into this manual "Generate" function of the Playlist Generator?
Really like the waveform on the coming up next tab. Maybe an option to change the colour of the waveform per section however? For our less advanced presenters with vision issues, they will mistake the playing track as the one on the right, as the waveform is the same colour as the current playing track. Would be good to be able to grey it out. I would also like to be able to see the waveform on the last played track for consistency/even UI.
I'd like to circle back to this. We like how the waveform is on all 3, but we're still having complaints of presenters not knowing which track is the active one due to the waveforms all being the same colour. Can we add an option to hide the waveforms (like previous versions) on the prev/next or change the colour of each of the waveforms individually.
There are also some minor UI inconsistencies that I've noticed:
1 - In the track, the text isn't aligned with the icons, as you can see with the red box.
2 - The text in the Search tab gets cut off by the boxes when the text is larger on a 1920x1080p screen.
3 - The track info box is no longer able to be customised individually and no longer has a border. We've found it makes the UI look really messy.
Previous version:
This version:
I've noticed a bug with the Queue mode. Here are the steps to replicate:
1 - Drag 2 tracks in the playlist.
2 - Play track 1, stop it after a few seconds. The track will remain in the playlist.
3 - Play track 2. It will delete track 1 the moment track 2 is played...
If this is expected behaviour, can it be changed haha? Maybe a threshold of when it becomes a played track? If you're auditioning your playlist off air (we can't use preview in our environment due to our infrastructure), we tend to just play all the tracks, then stopping it. But we do like the Queue mode when actually on-air. I understand this might be limited to just us, but keen to see what can be done. I definitely don't think playing a different track should have an effect on another one.
Here is a link to a video if that's been helpful - https://drive.google.com/file/d/1TxoCoPg214y9vo_PSAvkbeu2oDGQOX1C/view?usp=sharing
Previous version:
This version:
Yes, I also somehow preferred the info box in the previous version. The white background looked better to me than the current one, which is the same color as the frame — it helped separate it more clearly as a distinct element.
Also, before, when you clicked on a tag, the dash would blink so you knew something was happening. Now it just stays static, which is a bit confusing.
My vote goes to this design. (from the previous version 7.2.0.2)
Version 7.2.0.3 - When the information for all of the columns selected for the main playlist window don't fit within the visible playlist window they can not be accessed by using the horizontal slider at the bottom of the playlist window. Previous versions allowed access to the non-visible columns by using the slider.
I’ve mentioned this before, sometimes when I’m talking between two songs, an intro suddenly starts under me. I’ll be speaking live and - boom - the intro kicks in unexpectedly.
I really like the new Manuals option so commercials can’t surprise you when I talking. That’s a great improvement.
Maybe when Manuals is enabled, Auto Intro could also be temporarily disabled? So whenever you’re in manual mode, nothing can suddenly start under your voice.
That would make manual/live work feel much safer and more relaxed.
I already mentioned that introducing Manual Mode is a great addition, because it prevents commercials from unexpectedly starting while you're speaking.
As you mentioned earlier, I also hope there will be an option to disable Auto Intro while in this mode, so that nothing can interrupt you while you are talking.
I would just like to ask if it would be possible to assign a keyboard shortcut to Manual Mode, so I don't have to click around with the mouse, but can simply press a key in a quick and elegant way.
For example: when I go on air, I press a key and Manual Mode activates. When I finish speaking, I press the same key again and everything returns to normal automation mode.
That would be extremely useful for presenters.
Maybe it doesn't take the playlist's start time into account. I'll add this to the list of bugs to check.
This is expected as the logs show that it terminated earlier due to an error, before the required duration was generated.
Yes I think that would be possible.
Yes, this is still in the queue to be developed and I think will be added in .4 or .5 update.
Interesting, everything should be centrally aligned. Added to the list of bugs.
It doesn't look like a bug, seems that you increased the main window font too much, so it doesn't fit anymore. If you need to make everything larger, consider changing the scaling option in Windows, as this will properly scale control sizes as well as fonts. I'll see if we can add main window scaling option to the Styles so you can do it from within RadioBOSS.
Can you please specify what customization is missing? The frame doesn't seem to be ne3eded there as playlist and track info box have different background colors, so they are already separated visually.
It does seem that you should disable the queue mode while testing. From RadioBOSS perspective, it just does what it's instructed to do (delete played tracks, or not delete).
Another comment I have on the clock is that it really doesn't work with larger text, it just looks messy. Is there anything that can be done about that?
Make the Nowplaying area larger? (from View > Workspace > Customize). We're now exploring the idea of freely resizing it like resizing of the zones work now. This will allow to adjust its size as needed.
