Yes, the color needs to be adjusted there, thank you.After selecting an area outside the search list, the selection appears blank; it is not distinguishable as shown in the screenshot.
I think we should stick with one solution. Having a key combination is not really practical because no one will know about it, and to know it will require reading the user manual which few people doAs a possible solution for the played file-type icons, I think there could be a key or key combination to toggle between the two modes.
Alternatively, there could be a quick-access option to quickly display the played file-type icons.
I don't think moving the timer in between of a countdown is a good idea - that is, it starts on the left side during outro, thenit suddenly goes to to the right once the next track starts, this is not good. By seeing the playback position you know if it's either Intro or Outro. You may adjust the style settings to make played part more prominent.I have a complaint regarding the text that indicates “intro” inside the playback bar. It becomes confusing when it reaches the outro marker: the announcer does not know where to look because two countdown timers appear with different times. This makes it very confusing.
Wouldn’t it be better to display the word “outro” in the counter on the right side?
Yes, I think that would be possible for shorter tracks.Another important point: I would like the timers to be changed from 00:00.0 (longer) to 00.0s (shorter). This would save some space.
