RadioBOSS 7.2 [beta]
What's new
  • Virtual Mixer Console (RadioBOSS Ultimate)
  • Changes in the design of the main window
  • Styles: new default styles and more options to configure the main window appearance
  • Layout management window (menu View > Workspace > Customize): quickly hide/show UI elements
  • Next Track display improved: shows track markup and waveform
  • New tab yype: Clock
  • Dayparting: set when a track is allowed to play (hours/days of the week); used in the Playlist Generator and Track List (RadioBOSS Ultimate)
  • Playlist: added "Icon" column to display custom icons defined for file types
  • Playlist: added Start Date / End Date columns
  • Streaming: option to send StreamURL tag in stream metadata
  • Weather data retrieval can now be configured in settings; retrieve by geo position
  • Added "Fade on Pause" option in Settings > Playback > Fading
  • Track List: track is not re-rolled if not necessary
  • Advanced options: millisecond precision for Track Tool, shift Mix Point
  • Show duplicates and other options are now protected with UAC
  • Auto Intro: improved probability processing for rules (checks if a rule can actually be used first)
  • Auto Intro: improved error handling and reporting; playback can now be stopped
  • File Explorer tab: user interface improvements
  • API Users: new permission "Remote Ads Management"
  • Emoji characters can now be used for tab names
Scheduler
  • Event expiration handling improved
  • Improved events list display
Playlist Generator
  • New repeat protection option: do not play tracks at the same time as yesterday (RadioBOSS Ultimate)
  • Scheduler wizard: set expected start time for a generated playlist
  • Improved random track selection when priorities are not used
  • Improved "Create Multiple Playlists" window
Ads Scheduler
  • Additional variables can be used in playlist name templates
  • Multi-select for ads in the list
  • Remote export: allow specifying username
  • Option to set names for created events
Track Tool
  • Extended track zoom limit
  • Auto Detect option to set Start/End/Mix points
  • Improved performance
Minor Improvements
  • Multi-select option for "Add Tracks from Playlist"
  • Fixed: weather data from OpenWeatherMap was sometimes incomplete
  • Waveform is now the default visualization
  • Extended gap killed dB limit
  • Accessibility: hotkey (Shift+F9) to focus the "Remaining Time" text
  • Fixed: Report Generator did not read profile settings when launched directly
  • Fixed sorting in Music Library for some columns
  • Fixed: commands were not executed inside a container
  • Fixed: pipe character was not properly displayed in Now Playing
  • Fixed: some HLS streams did not play
  • Fixed: exported artwork was not reset on stop
  • Improved high-DPI screen support
  • Fixed: waveform was not displayed for tracks longer than 30 minutes
  • Several options related to Stream Archive moved out of Advanced Settings
  • Fixed weather data display in dark themes
  • "Smooth Level Meter" option moved out of Advanced Settings
License key
The free key expires May 15, 2026.
RadioBOSS 7.2 beta
x86 https://dl.djsoft.net/beta/radioboss_setup_7.2.0.9.exe (4/4/2026, 32MB)
x64 https://dl.djsoft.net/beta/radioboss_setup_7.2.0.9_x64.exe (4/4/2026, 36MB)
For the convenience of all members, please write your posts in English only. Thank you!
Hello friend, I've been a subscriber for many years and I hope to become even more loyal to Radio Boss. I don't even know if I'll have the opportunity to receive this version, but I pay for the Advanced version. Let's see the modifications. One thing I've always wanted is a virtual mixer so that many other users can use this device as they would in a normal radio station with a radio console, and now virtually, that's great. I haven't seen it yet; I still have the version that doesn't have this appearance, but I'll try to download and check out this new version that's already been released... Thank you to you at Radio Boss. I'm here in Brazil, hoping that everything goes well for all of us users and for you on the team. God bless you all. We move forward with the best radio program.
Olá amigo, sou assinante há muitos anos e espero me tornar ainda mais fiel ao Radio Boss. Nem sei se terei a oportunidade de receber esta versão, mas pago pela versão Avançada. Vamos ver as modificações. Uma coisa que sempre quis foi um mixer virtual para que muitos outros usuários pudessem usar este dispositivo como fariam em uma estação de rádio normal com um console de rádio, e agora virtualmente, isso é ótimo. Ainda não vi; ainda tenho a versão que não tem essa aparência, mas vou tentar baixar e conferir esta nova versão que já foi lançada... Obrigado a vocês do Radio Boss. Estou aqui no Brasil, esperando que tudo corra bem para todos nós usuários e para vocês da equipe. Deus abençoe a todos. Seguimos em frente com o melhor programa de rádio.
somos do Brasil!!!!!!!!!!!!!
Report Generator > Export (Translate)
Is it possible to add all the lines and the confirmation to the language file for translation?​
These are the formats: "PDF" (4 tabs: "Export", "Information", "Security", "Viewer"), "RTF", "Text file", "CSV", "HTML" + the confirmation "Report exported successfully".​
Report Generator > Export (bug)
There's a small bug: when I cancel the export, the "Report exported successfully" window appears. This window shouldn't appear: the export has been canceled and therefore cannot be completed.​
Redesigned the Advanced Settings window (Translate)
Thank you for this improved display: it highlights the different categories (Audio, Playlist, Scheduler, UI, etc.) and makes it easier to configure advanced settings. It's more organized and clear.​
Is it possible to add this content to the language file for translation?​
Same question for the new "send Overlay event titles when Relaying" option.
Playlist Generator > Settings > Do not play tracks at the same time as yesterday
This new option works perfectly and accurately takes into account the last 5 times the track was played. This prevents the feeling of always playing the same track at the same time.​
I have a similar suggestion: Is it possible to add a new option for tracks that weren't played yesterday but later: to avoid playing the same tracks at the same time as last time, with different "Before" and "After" settings?​
This option would prevent the same track from being played at the same time every day, even if it's in a category that allows tracks to be played all day. Personally, I have several tracks that play constantly, either at the beginning or end of the day.​
This option would be useful for "Oldies," "Gold," and "Recurring" tracks, which don't have the same rotation frequency as "Hits." These are tracks that are played once every two days, once every three days, or even once a week or more.​
The goal is to avoid the impression that a track is only for the morning, afternoon, or evening.​
If it is approved, I hope that it can be added in this new version 7.2.​
Playlist (Player)
Is it possible to add the "language" column?​
Sorry, the sentence above was not translated correctly :(. I meant to say:
This option would prevent playing a track at the same time as the last time.​
Personally, I have several tracks that play constantly at the end of the day or the beginning of the day.​
However, these Tracks are in a category that allows them to be played all day.​
Paulo Roberto, es do Brasil , estamos juntos , esse na minha opnião é o melhor softwere para Web Rádios e Rádios convencionais diga se profissionais, é bem descomplicado e leve, roda liso. To aqui na especatativa do lançamento desta nova versão, não tenho ideia como será o mixer virtual que é um sonho ter, pois muitos novos usuarios ficarão felizes pois é algo muito funcional e moderno para hoje em dia em uma rádio , os consoles agora serão digitais, chega de tranbolhos e coisas pesadas e caras demais, já é dificil montar uma radio hoje em dia , imagina o preço de materiais que hoje as importadoras cobram o olho da cara...vamos sobrevivendo pelo amor a profissão de radialiste e amor ao rádio em si...Viva o Rádio Boss
