RadioBOSS 7.2 [beta]
The total length and remaining length of the active playlist are not displayed
Between the current track and the next track, another field appears that shows the remaining time for the current track.
This happens in all designs.
Where can I hide this? Or is this a bug?
Every time you make even the slightest change in the settings, this pop-up message appears.
This is very annoying, especially since the changes are saved even WITHOUT restarting RadioBOSS.
We seen this reported by other users too, but it wasn't reproduced here yet. Hopefully it will get sorted out in the next release.
Looks like you have the Screen Reader mode enabled. You can disable it in View > Accessibility menu.
Can't find. Where is the dayparting for Auto Intro option?
Dayparting can be configured using Track Tool.
Music Library > select the track > Open Track Tool > Dayparting.​
This works when selecting an intro track for Auto Intro.
Dayparting also works when a playlist is created using the Playlist Generator, when a track is selected using Track List and in the Ad Scheduler for block Sweepers, Intro, and Outro.
Or Music Library > select the track > Open Track Properties > Dayparting.
Are the big black lines really necessary... The ones separating the different sections.
Just wondering
If you click on the group name (Tanda) and drag the entire group into the playlist, it gives the error shown in the attachment. However, if you select the whole group and then drag it there, everything copies correctly.
Thank you, we'll check it.
When I right-click on the track(s) I want to move to another tab, the tab options do not appear: MOVE TO
Can you please send a screenshot?
The tabs are behaving strangely. They change position and drag their playlists to another tab.
Can you please provide more details about it?
Now it does nothing when you drag the entire group. Is that the fix you made?
If your answer is “Yes,” why doesn’t it move the whole group to the playlist?
It only allows dragging the events, dragging of the groups is not supported.
Hot Keys:
"Mute" doesn't seem to work.​
All other shortcuts work correctly.​
Translation:
Is it possible to add "Additional 2" to the translation file?​
View > Workspace > Customize > Additional 2​
("Additional 2" is already added in "Work zones")​
Wouldn't it be better to add "1" to the first "Additional"?​
RadioBOSS 7.2.1.3 beta
Changes
  • Fixed bugs related to "Main window zoom"
  • Fixed tabs with playlist tabs
  • Other reported bugs fixed; minor improvements
x86 https://dl.djsoft.net/beta/radioboss_setup_7.2.1.3.exe
x64 https://dl.djsoft.net/beta/radioboss_setup_7.2.1.3_x64.exe
The slider that is found when viewing fx by either going to the view menu, or pressing f4 is still not reading with NVDA as it did in 7.1. The output can be changed with the arrow keys, but this is something to avoid until the accessibility can be restored, otherwise its hard to know when you're at +0db.
