RadioBOSS 7.2 [beta]
The total length and remaining length of the active playlist are not displayed
Between the current track and the next track, another field appears that shows the remaining time for the current track.
This happens in all designs.
Where can I hide this? Or is this a bug?
Every time you make even the slightest change in the settings, this pop-up message appears.
This is very annoying, especially since the changes are saved even WITHOUT restarting RadioBOSS.
We seen this reported by other users too, but it wasn't reproduced here yet. Hopefully it will get sorted out in the next release.
Looks like you have the Screen Reader mode enabled. You can disable it in View > Accessibility menu.
Can't find. Where is the dayparting for Auto Intro option?
Dayparting can be configured using Track Tool.
Music Library > select the track > Open Track Tool > Dayparting.​
This works when selecting an intro track for Auto Intro.
Dayparting also works when a playlist is created using the Playlist Generator, when a track is selected using Track List and in the Ad Scheduler for block Sweepers, Intro, and Outro.
Or Music Library > select the track > Open Track Properties > Dayparting.
Are the big black lines really necessary... The ones separating the different sections.
Just wondering
