patrick.de-bruyn
The total length and remaining length of the active playlist are not displayed
We seen this reported by other users too, but it wasn't reproduced here yet. Hopefully it will get sorted out in the next release.Every time you make even the slightest change in the settings, this pop-up message appears.
This is very annoying, especially since the changes are saved even WITHOUT restarting RadioBOSS.
Looks like you have the Screen Reader mode enabled. You can disable it in View > Accessibility menu.Between the current track and the next track, another field appears that shows the remaining time for the current track.
This happens in all designs.
Where can I hide this? Or is this a bug?
ooops ok solved both issues, thank youLooks like you have the Screen Reader mode enabled. You can disable it in View > Accessibility menu.
Dayparting can be configured using Track Tool.Can't find. Where is the dayparting for Auto Intro option?
Or Music Library > select the track > Open Track Properties > Dayparting.Dayparting can be configured using Track Tool.
Music Library > select the track > Open Track Tool > Dayparting.
This works when selecting an intro track for Auto Intro.
Dayparting also works when a playlist is created using the Playlist Generator, when a track is selected using Track List and in the Ad Scheduler for block Sweepers, Intro, and Outro.
It is not an option, it is taken into account when selecting the Auto Intro tracks.Can't find. Where is the dayparting for Auto Intro option?
Not really, we'll consider changing them to be the same as in the main RadioBOSS window.Are the big black lines really necessary... The ones separating the different sections.
Just wondering
Thank you, we'll check it.If you click on the group name (Tanda) and drag the entire group into the playlist, it gives the error shown in the attachment. However, if you select the whole group and then drag it there, everything copies correctly.
Can you please send a screenshot?When I right-click on the track(s) I want to move to another tab, the tab options do not appear: MOVE TO
Can you please provide more details about it?The tabs are behaving strangely. They change position and drag their playlists to another tab.
It only allows dragging the events, dragging of the groups is not supported.Now it does nothing when you drag the entire group. Is that the fix you made?
If your answer is “Yes,” why doesn’t it move the whole group to the playlist?
