RadioBOSS 7.2 [beta]
"Mute" doesn't seem to work.
Mute is actually Mute Monitor - it only mutes the Monitor sound card and not the Main.
Is it possible to add "Additional 2" to the translation file?
View > Workspace > Customize > Additional 2("Additional 2" is already added in "Work zones")
Wouldn't it be better to add "1" to the first "Additional"?
Yes, this is in the dev queue for the next update. I'm not sure about the additional work zone naming, usually #1 is not named and other do, like they do with movies/games.
The slider that is found when viewing fx by either going to the view menu, or pressing f4 is still not reading with NVDA as it did in 7.1. The output can be changed with the arrow keys, but this is something to avoid until the accessibility can be restored, otherwise its hard to know when you're at +0db.
We'll check it, thank you.
For this you should use the other playlist tabs, or load it to the main playlist tab. Also, scheduled events with the "Overlay playback" flag can also sent their titles, but it needs to be enabled in the settings: https://manual.djsoft.net/radioboss/en/schedule_settings.htm
I don't think sending the titles from cart wall make much sense, carts are designed to be quick effects playing on top of the main content, changing the title from there seems unexpected. Same, for a lesser extent, is true for AUX players.
I think using the other tabs of the playlist as a player is makeshift work unworthy of software like RadioBOSS. It's a shame not to keep the idea for a future edition.
Tracklists contained within a container still not working.
I'm not sure sending track titles from cart wall is a useful thing to do. Currently it looks like very situational and not something what many users will be benefit from, I'm sorry.
