RadioBOSS 7.2 [beta]
"Mute" doesn't seem to work.
Mute is actually Mute Monitor - it only mutes the Monitor sound card and not the Main.
Is it possible to add "Additional 2" to the translation file?
View > Workspace > Customize > Additional 2("Additional 2" is already added in "Work zones")
Wouldn't it be better to add "1" to the first "Additional"?
Yes, this is in the dev queue for the next update. I'm not sure about the additional work zone naming, usually #1 is not named and other do, like they do with movies/games.
The slider that is found when viewing fx by either going to the view menu, or pressing f4 is still not reading with NVDA as it did in 7.1. The output can be changed with the arrow keys, but this is something to avoid until the accessibility can be restored, otherwise its hard to know when you're at +0db.
We'll check it, thank you.
For this you should use the other playlist tabs, or load it to the main playlist tab. Also, scheduled events with the "Overlay playback" flag can also sent their titles, but it needs to be enabled in the settings: https://manual.djsoft.net/radioboss/en/schedule_settings.htm
I don't think sending the titles from cart wall make much sense, carts are designed to be quick effects playing on top of the main content, changing the title from there seems unexpected. Same, for a lesser extent, is true for AUX players.
I think using the other tabs of the playlist as a player is makeshift work unworthy of software like RadioBOSS. It's a shame not to keep the idea for a future edition.
Tracklists contained within a container still not working.
I'm not sure sending track titles from cart wall is a useful thing to do. Currently it looks like very situational and not something what many users will be benefit from, I'm sorry.
This error sometimes appears; instead of the waveform, a line appears. It happens occasionally.
Just an idea - could we add an option to be able to drag from the playlist to the cart wall? So the file goes onto the cart wall? Similar to a file explorer drag an drop
It happens sporadically, mostly with short tracks (IDS-SWP). And yes, I'm using the latest version.
This happens regardless of the track's duration for me.
Specifically, it occurs when changing or deleting a track after the currently playing track. And when I move that track back after the currently playing track, the waveform reappears. Is this a refresh issue? (I'm using the latest version)
Could be a bug with caching, for some reason RadioBOSS decices it doesn't need to load a waveform. Added to the list of bugs.
This is possible if you drag it by the track icon.
i buy in minuts the new UPDATE.....go go to the new and advanced Radio Boss for play radio
RadioBOSS 7.2.1.4 beta
Changes
  • Several bug fixes regarding crossfading calculation
  • Segue Editor: shows a warning if a sileng gap is detected between the tracks
  • Segue Editor: fixed a bug when playback didn't match track configuration
  • Fixed: next track waveform was empty sometimes
  • Improved fading for AUX playlists
  • Gain slider in the main window made accessible
  • Seting backup feature now saves the profile before performing backup
  • Fixed: sometimes containers with Track List items did not work
x86 https://dl.djsoft.net/beta/radioboss_setup_7.2.1.4.exe
x64 https://dl.djsoft.net/beta/radioboss_setup_7.2.1.4_x64.exe
Beta 7.2.1.4 32 Bit on Windows 11
If you assign a specific color to each playlist tab,
and the active playlist always has a red tab, for example, the tabs with different colors won't turn red when that playlist is set as active.
Changes
(playlist icon size) even changing the size does not have any effect on the play icon and it is very small.
Beta 7.2.1.4 32 bit - Win 11
Normalizing songs doesn't work in TrackTool unless you adjust the slider manually.
I have the track level set to -13.0 LUFS, but nothing happens when I click the Normalize button.
I tested this with a song I created using MP3Gain with intentionally different volume levels.
This is by design. Do you thing the active tab color should take precedence over the active tab color?
Thank you, we'll check it.
This doesn't confirm here, changing the "Playlist icon size" option in Settings > View > Style does change the icon size. Note that there's another option "UI Icon size" - it doesn't affect the playlist icon size.
