RadioBOSS 7.2 [beta]
Auto Intro
In Playlist > Auto Intro > select a rule (Rule) > The "Must not contain tags" checkbox
The background of the rectangle displaying the selected tags is a different color for all display styles: light gray. This stands out in the "Black" style. Is it possible to correct the background of this rectangle for aesthetic reasons and consistency with the other elements?
Is it possible to add "All" and "Any" to the translation file for this "Must not contain tags" line? (Or, if possible, assign the same keys as the line above.)
Translation
Music Library > Tools > Track properties
Is it possible to add "Prelisten", "Prev", and "Next" to the language file?
Will be fixed in the next update.
Translation
Noted, thank you.
RadioBOSS 7.2.1.4 beta
Changes
  • Several bug fixes regarding crossfading calculation
  • Segue Editor: shows a warning if a sileng gap is detected between the tracks
  • Segue Editor: fixed a bug when playback didn't match track configuration
  • Fixed: next track waveform was empty sometimes
  • Improved fading for AUX playlists
  • Gain slider in the main window made accessible
  • Seting backup feature now saves the profile before performing backup
  • Fixed: sometimes containers with Track List items did not work
x86 https://dl.djsoft.net/beta/radioboss_setup_7.2.1.4.exe
x64 https://dl.djsoft.net/beta/radioboss_setup_7.2.1.4_x64.exe
Hello Radio Boss friends, I'm having trouble adding an audio processor to the beta version of the DSP. I currently use JB Broadcaster, and in this new version I can't add one to improve the transmission quality of both music and other files. It would be important for the software itself to have a built-in audio processor, as the quality improves exponentially. Can you help me look into this? I noticed that the Winamp VST application window isn't open, and that's why I can't add this processor. The sound quality is very good with JB Broadcaster.
Winamp DSP works in 32bit version... I think.
But for 64bit there's a 64bit VST called ToneBoosters TB Broadcast V3. It's an improved version of JB Broadcaster. It's also free
remember JB Broadcaster ist a 32 bit VST plugin , it dousnt work in64bit radioBOSS
There is a VST Plugin similar to JB broadcaster named TB_Broadcast_v3
You can Download TB Broadcaster from my Cloud
TB Broadcaster for RB 64 Bit
Please see this guide about using the plugins: https://www.djsoft.net/community/threads/using-winamp-dsp-plugins-in-radioboss.3480/
If you have RadioBOSS 64-bit, Winamp plugins can't be used.
Yes it should always change to red iff ist set to red in the design options
Those are conflicting options, the "Active playlist color" and "Color specified for a tab". According to the design rules, a tab-specific color should have higher priority over the more general active playlist color. Is it OK that you "lose" the tab's color when you mark the tab as active playlist?
In the current version 7.1.6.2, a playlist with a custom tab color changes color as specified in the design settings. For me, the active playlist tab should always be red.
When I select a different playlist, the previous playlist retains its custom color.
It’s fine with me if a playlist tab turns red when active and then reverts to its custom color when another playlist becomes active.
Why doesn’t this work in the demo version?
Hello administrator, I have a suggestion before releasing the official version: could you add some cheats or change the activation method to make it more difficult for pirates? Thanks.
The gain sliders behavior is a bit strange. Pressing up/down arrow, or either the alt or control key will keep dropping the volume. The only way to increase the volume of the slider s to use the left/right arrow.
This was actually decided as a bug, because that tab color was not retained. While active tab is already marked in bold font. So how it works presently you see both: if the tab is active and its custom color. Maybe we'll add an option to set what color should get the priority.
Thank you for the suggestion. There's some protection in place, and putting more effort into it seems counter-productive - we'd best spend time/money/effort on making the product better rather than fighting those "pirate" people.
As it's a horizontal slider it's designed to handle left/right arrow keys to change its value. We'll check if it should also handle up/down keys properly.
