RadioBOSS 7.2 [beta]
stil dousnt normalize tracks at all
What error message does it show?
In the tracktool no error messages it just dousnt do anything
Data base see Pic... all titles give error, no matter they are from disc C or any other Disc and No Writhe protection
Neither of this reproduce here. Normalization works in both Music Library and in Track Tool.
In the Music Library you can click the View Errors button to see the details.
As for the error messages, Track Tool does a quick skip if a track doesn't exist (or a file is unreadable), with no error message. We'll fix it (add an error message). But the core issue seems to be file access problems.
Those system requirements are for RadioBOSS 7.1, which is presently the latest stable version. I did a quick test on a testing Windows 7 machine, and it runs fine there. Does version 7.1 work for you?
About RadioBOSS 7.2 it also runs on Windows 7 machine, but there are some UI issues, apart from that, it's working.
Are there any error messages when you try to run either version? I'd also like to point out that it will only run if Service Pack 1 is installed. You can check it in Winver application (press Ctrl+R enter winver and press Enter).
