Generate 24 Playlists with New Playlist Generation Commands System ?
Altec
Hello Dmitri,
Thank you to add the possibility to generate multiple playlists with a preset. But I can't find how to generate 24 Playlists properly.
Before the Update I was working like this :
I tried your marvellous new options, but I can't find how set the start number for each preset, exemple ALTEC-NIGHT Start Number is 0, Altermorning Is 6 to reach at the end 24 hours and 24 playlists :
I tried to modify the command like this :
"C:\Program Files (x86)\RadioBOSS\PlaylistGeneratorPro.exe" "-preset=ALTEC-NIGHT|ALTEC-MORN|ALTEC-LUNCH|ALTEC-AFTERNOON|ALTEC-AFTERWORK|ALTEC-EVENING" "-out=C:\PL\playlist_%nn.m3u8|playlist_%nn.m3u8|playlist_%nn.m3u8|playlist_%nn.m3u8|playlist_%nn.m3u8|playlist_%nn.m3u8" -n=6|6|2|4|2|4 -s=0|6|12|14|18|20 "-starttime=00:00:00" "-startday=1"
But it doesn't work, I tried that too :
Doesn't work
It could be useful to move there the "Start number" option... :
Thank You in advance
An option to set the start number for each batch will be added in one of the next updated. Currently it's only increased sequentially across all generated playlists in a command.
Is it currently possible to do what I want to do—perhaps by using a hidden argument in the command—or is that not possible yet?
There are no hidden arguments for this, the processing of -s parameter needs to be extended, and this will be done in one of the future updates. Maybe it'll be added in 7.2.2 minor update.
Thank you very much. Can you also add an argument "tomorrow" for that
Because I'm using pl generator to generate the 24 hours approximately at 11pm the day before.
Thank you in advance
