Fade In/Fade Out noise artefact bug
Altec
Hi Dmitriy,
I don't know exactly if it's due to the last releases but from a moment I heard sometimes fades bugs in the songs transitions. I saw that it's happen more often when there is a custom fade in or fade out set into the track tool.
here is an example
Best regards
When playing it doesn't really matter where the fading number comes from (general settings, track tool, etc.) - the processing is the same always.
What is happening in those mixes? There's a clicking sound, but maybe it presents in the files themselves?
We have also been experiencing this issue since the latest updates. Often, after a long fade, the track that was just playing in the studio drops to minus infinity at the mix point and the new track starts. Then, when the previous track completely finishes. I would say about 1 to 2 seconds later . We hear a quick 1-second fragment of that previous track.
Exactly
As JeanXeb said, I have experienced the same problem, and it doesn't come from the tracks. I constated that the problem happened when the tracks before or after had fade in or fade out defined into the tracktool. I feel like it has a confflict between fade into the tracktools and fades set into radioboss studio parameter "Crossfades"
Best
How often does it happen, and how long is the fade?
The conflict is not really possible there as in the end it comes down to one number (fade duration, or any other thing it needs to calculate). If this happens with some tracks does it always happen or it's occasional?
I'll verify that.
I think it depends if the position is of the end point is for example 3 second after the mix and you have configured crossfades at 2.5, I have the impression there is a problem there.
You understand what I mean ?
