Fade In/Fade Out noise artefact bug
Altec
Hi Dmitriy,
I don't know exactly if it's due to the last releases but from a moment I heard sometimes fades bugs in the songs transitions. I saw that it's happen more often when there is a custom fade in or fade out set into the track tool.
here is an example
Best regards
When playing it doesn't really matter where the fading number comes from (general settings, track tool, etc.) - the processing is the same always.
What is happening in those mixes? There's a clicking sound, but maybe it presents in the files themselves?
We have also been experiencing this issue since the latest updates. Often, after a long fade, the track that was just playing in the studio drops to minus infinity at the mix point and the new track starts. Then, when the previous track completely finishes. I would say about 1 to 2 seconds later . We hear a quick 1-second fragment of that previous track.
Exactly
As JeanXeb said, I have experienced the same problem, and it doesn't come from the tracks. I constated that the problem happened when the tracks before or after had fade in or fade out defined into the tracktool. I feel like it has a confflict between fade into the tracktools and fades set into radioboss studio parameter "Crossfades"
Best
How often does it happen, and how long is the fade?
The conflict is not really possible there as in the end it comes down to one number (fade duration, or any other thing it needs to calculate). If this happens with some tracks does it always happen or it's occasional?
I'll verify that.
I think it depends if the position is of the end point is for example 3 second after the mix and you have configured crossfades at 2.5, I have the impression there is a problem there.
You understand what I mean ?
The problem happens on tracks without Fade/in Fade Out defined... Maybe that's tracks with Outros defined... I can't find out what is the origin of this bug...
On your screenshot, there is Fade Out marker set. In any case, we'll check what could be wrong there, thank you for the information. From how it sounds looks like after the fade ends it briefly plays several samples at 100% volume level.
We've had serious issues this weekend where the playlist just stops and 48 hours later, NO response from support via email or on our ticket. TERRIBLE SERVICE for such a good product! When something goes wrong, don't expect any help. Not soon anyway.
Some of our staff are on vacation so response times are higher than usual. But in most cases the response is provided within 24 hours, sometimes a bit longer.
UPDATE : The problem can happen randomly on tracks with or without defined fades or outro, so it seems that's not linked.
Thank you for your help
Sorry but that's not true, I think this is the summer holidays so the service is minimum, but all around the year Djsoft is always here for us to implement, correct, or give help.
Sorry if you have problems not solved but i think that's just not the good period for them
Altec
The problem still not resolved in the new version... I don't understand why
The main difficulty is that the problem was not reproduced here, but still some adjustments were made to handle some potential issues. For now, there seems to be nothing else we can do about it.
