Remote Playlist Editor and Voicetracking
Roland
Hi all, I have written a hobby project for our radio station in Delphi, which is allready in use for over one year:
Remote Playlist Editor Software with Voicetracking (64 Bit Version only).
Connects to a RadioBOSS installation via RadioBOSS API and also SQL database. For accessing Audio-/Playlist-Files I'm using FTP/FTPS/SFTP.
Presenters can record voice tracks from any location and insert them into any upcoming playlist – regardless of what is currently on air.
Key features:
• Remote voice tracking: record directly into any FTP directory, not just the current OnAir playlist
• Remote editing of playlists and OnAir queue
• Real-time display of current track, next track and relay status
• Full keyboard operation and TTS speech guidance for blind users
• Cue Point Editor: waveform display, 10 cue points, LUFS normalization, database integration
• Tag Editor: edit metadata, calculate BPM, automatically find release year (MusicBrainz/iTunes)
• Song search in RadioBOSS media library with repeat-play filter
• Insert RadioBOSS control commands into playlists or execute directly
• Preset system: save and load directory configurations for different shows
• Supports FTP (active/passive), FTPS (SSL) and SFTP (libssh2)
• Integrated help system (F1), context-sensitive
• Currently available in five languages: German, English, French, Spanish, Turkish
As I said first: it is just a hobby project in let me say "beta-state" without any warranty!
If somebody is interested in beta-testing, I have attached the current version 1.0.118 (dated 2026-07-04) as zip File.
I have posted this here because I'm just looking for getting more user feedback for optimizing, you are also especialy invited djsoft-team!
I am not going to sell this project, it is just a great support to our radio station and maybe also for other people broadcasting by RadioBOSS!
  • RemotePLE_v1.0.118.zip
Today I've added a new feature:
(under FTP settings) Local mode: If Your RadioBOSS PC is in the same network than the remote PC you can also use a local LAN share for accessing the files RadioBOSS is using for broadcasting.
From now on there are two ways available to use RemotePLE:
. Portable version: simply unzip in any folder (works only for the user on the current pc, but You can disable password encryption, then it is fully portable e.g. on USB Stick: Add the line NoPwEncrypt=1 under [Init] in RemotePLE.ini - but Your passwords are then readable)
. Installer version: Install as any other Windows Application (only for current user), so you can update it further without overwriting your settings or uninstall it if needed.
Latest (Beta-) Versions can now downloaded at https://buck-edv.de/apps/RemotePLE/ (the page is available in German only for now)
New portable version is added.
best regards
Roland
I have now translated the download-page to the five languages RemotePLE is using (German, English, French, Spanish, Turkish).
The new version 1.0.0.120 now provides server profiles (several RadioBOSS servers)
  • New: Server profiles. You can now manage several RadioBOSS servers or stations as profiles and switch between them while the program is running. Each profile bundles the connection, RadioBOSS access, SQL database and its own preset list. Open the server profile window with the F11 key. The active profile is shown in the title bar. On the first start your previous settings are transferred automatically into a profile named "Standard" and can be renamed later.
  • Protection against invalid paths: Tracks outside the music root directory are no longer added to the playlist or to the RadioBOSS commands, but skipped with a message.
  • Bug fix: In SFTP mode presets could not be loaded (they previously were marked as invalid). Presets and playlists now also work over SFTP.
Thanks for Your (y)Feedback PAULO ROBERTO!
best regards
Roland
Version 1.0.0.121 is now available: Built-in text editor and further improvements
  • New: Built-in text editor. Text files on the server (txt, csv, cue, tag) can now be edited directly in RemotePLE - in the FTP tab as well as in the source lists. Open them by double-clicking, via the context menu "Edit file" or with Ctrl+E. When you save, the file is automatically uploaded back to the server. The character encoding (ANSI, UTF-8, UTF-16) is detected and preserved on saving. The editor is fully operable by keyboard and speech; while scrolling, the current line is read out. Text files also get their own icon in the lists.
  • New: Notification of new versions. If no automatic update is set up, RemotePLE can check online for a newer version at startup and show a notice. Can be turned on and off in the settings under "Advanced".
  • New: Speech on mouse movement. The announcement of hints under the mouse pointer now only reacts to actual mouse movement - a pointer left in place no longer repeats itself. Can now be disabled in the settings under "Speech".
  • New: Voicetracks recorded by RemotePLE can now be cutted in the Cue-Editor. Just set the "FadeIn" (F1) cuepoint as startpoint and maybe the "CueOut" (F10) cuepoint as endpoint for the voicetrack, then press Ctrl+B or the cut-button and after the confirmation, the file is shortened and uploaded back to the origin place. Cues and tags can not be saved for voicetracks in the Tag-Editor.
    (Lifetime for voictracks is normally just for on show, afterwards they will be deleted, so we dont want to spam the DB with entries obsolete in the near future) (Cue-/Tag-Editor is only available with configured SQL connection, open/close it by Ctrl+T).
Does anybody has suggestions for other/extended features? I'm just looking for getting more user feedback for optimizing RemotePLE, but a simple "works well for me" is also welcome;).
best regards
Roland
Version 1.0.0.124 is now available: Multiple root paths
  • New: Multiple root paths. The mapping between FTP paths and the drives on the RadioBOSS machine is now managed through a list on the
    "Common" tab. If your audio files are spread across several drives, you can add a separate mapping per drive.
    A single entry is still enough for the simple case; existing settings are migrated automatically.
  • Changed: The "SQL settings" tab is now called "RadioBOSS" and groups the RadioBOSS API, relay, trigger, livestream
    and database settings in one place.
  • Changed: In local mode (studio mode) the local paths are now entered in the "Local path" column of the root mapping;
    the FTP host field is no longer needed there.
  • since Version 1.0.0.123: Speech output improvements
    in the version notes, navigating now reads whole paragraphs at once instead of individual wrapped lines. This improves intonation;
    each bullet point is spoken as a complete sentence and decorative lines of equal signs are skipped.
    Special and punctuation characters can be announced by name when reading aloud, for example comma, semicolon or slash. Selectable in
    the settings under "Speech output": off, structural characters only, or all characters. Affects the internal text editor and the settings readout. In the text editor a short pause is inserted after each semicolon so data fields in CSV or cue files are easier to tell apart.
  • since Version 1.0.0.122: Now Playing (send the title to RadioBOSS API)
    RemotePLE can receive the title currently playing in a broadcast player (for example Traktor or Mixxx) and send it automatically to RadioBOSS as the cast title. This is useful when the sound is fed directly from a mixer into the sound card input of RadioBOSS, which otherwise knows no title. No extra Icecast service is needed - RemotePLE accepts the broadcast itself.
    Set it up in the settings under "Extended": port, on/off and the choice between the remote and the local RadioBOSS instance.
    The setting belongs to the current server profile.
best regards
Roland
Hello DJSoft Team, hello Dmitry,
I am currently adding support for listener song requests to RemotePLE.
It reads the queue with songrequestlist and inserts a chosen request either into a playlist that RemotePLE edits itself or into the on-air list, the latter through the API action inserttrack. That part works well.
There is one gap I would like to ask you about.
songrequestlist reports a played attribute, but there is no API action to set it. From testing on my own instance I see that RadioBOSS sets the flag when a request is dispatched from its own request window — even while playback is stopped — while an insert made through the API does not set it at all. So a request taken over by an external tool stays played="False" indefinitely, and there is no way to tell the server it has been handled.
At the moment I work around this with a list kept inside my application, but that memory is lost when the program restarts, and it is invisible to any other client or to a second operator working on the same station. A server-side flag would solve both.
Would you consider adding something like:
action=songrequestsetplayed&filename=<full path>
action=songrequestsetplayed&filename=<full path>&all=1
  • without all – marks the oldest matching entry as played
  • with all=1 – marks every entry with that filename as played
I would deliberately not add any further selector. Requests carry no id, so identity can only be formed from the filename, and a positional index would be unreliable: the list can change between the read and the write. Restricting it to "oldest match" and "all matches" keeps the behaviour predictable in every case. The all=1 variant matters when the same track has been requested several times with different greetings.
The existing songrequestclear already covers the "empty everything" case, so nothing further would be needed.
If you would rather solve it differently — for example by exposing a stable id per request in songrequestlist — that would work just as well for me, and it would make the API cleaner in the long run. Either way I would be glad to test an implementation.
Thank you very much for RadioBOSS and for keeping the API as open as it is. It is what makes a project like mine possible in the first place.
Best regards,
Roland
Each request has an "id" attribute to identify the requests. There's undocumented songrequestdelete command that you can use to delete individual requests - it takes a single id parameter. Perhaps you can use that to cross off the processed requests.
