Remote Playlist Editor and Voicetracking
Roland
Hi all, I have written a hobby project for our radio station in Delphi, which is allready in use for over one year:
Remote Playlist Editor Software with Voicetracking (64 Bit Version only).
Connects to a RadioBOSS installation via RadioBOSS API and also SQL database. For accessing Audio-/Playlist-Files I'm using FTP/FTPS/SFTP.
Presenters can record voice tracks from any location and insert them into any upcoming playlist – regardless of what is currently on air.
Key features:
• Remote voice tracking: record directly into any FTP directory, not just the current OnAir playlist
• Remote editing of playlists and OnAir queue
• Real-time display of current track, next track and relay status
• Full keyboard operation and TTS speech guidance for blind users
• Cue Point Editor: waveform display, 10 cue points, LUFS normalization, database integration
• Tag Editor: edit metadata, calculate BPM, automatically find release year (MusicBrainz/iTunes)
• Song search in RadioBOSS media library with repeat-play filter
• Insert RadioBOSS control commands into playlists or execute directly
• Preset system: save and load directory configurations for different shows
• Supports FTP (active/passive), FTPS (SSL) and SFTP (libssh2)
• Integrated help system (F1), context-sensitive
• Currently available in five languages: German, English, French, Spanish, Turkish
As I said first: it is just a hobby project in let me say "beta-state" without any warranty!
If somebody is interested in beta-testing, I have attached the current version 1.0.118 (dated 2026-07-04) as zip File.
I have posted this here because I'm just looking for getting more user feedback for optimizing, you are also especialy invited djsoft-team!
I am not going to sell this project, it is just a great support to our radio station and maybe also for other people broadcasting by RadioBOSS!
Today I've added a new feature:
(under FTP settings) Local mode: If Your RadioBOSS PC is in the same network than the remote PC you can also use a local LAN share for accessing the files RadioBOSS is using for broadcasting.
From now on there are two ways available to use RemotePLE:
. Portable version: simply unzip in any folder (works only for the user on the current pc, but You can disable password encryption, then it is fully portable e.g. on USB Stick: Add the line NoPwEncrypt=1 under [Init] in RemotePLE.ini - but Your passwords are then readable)
. Installer version: Install as any other Windows Application (only for current user), so you can update it further without overwriting your settings or uninstall it if needed.
Latest (Beta-) Versions can now downloaded at https://buck-edv.de/apps/RemotePLE/ (the page is available in German only for now)
New portable version is added.
best regards
Roland
I have now translated the download-page to the five languages RemotePLE is using (German, English, French, Spanish, Turkish).
The new version 1.0.0.120 now provides server profiles (several RadioBOSS servers)
  • New: Server profiles. You can now manage several RadioBOSS servers or stations as profiles and switch between them while the program is running. Each profile bundles the connection, RadioBOSS access, SQL database and its own preset list. Open the server profile window with the F11 key. The active profile is shown in the title bar. On the first start your previous settings are transferred automatically into a profile named "Standard" and can be renamed later.
  • Protection against invalid paths: Tracks outside the music root directory are no longer added to the playlist or to the RadioBOSS commands, but skipped with a message.
  • Bug fix: In SFTP mode presets could not be loaded (they previously were marked as invalid). Presets and playlists now also work over SFTP.
Thanks for Your (y)Feedback PAULO ROBERTO!
best regards
Roland
Version 1.0.0.121 is now available: Built-in text editor and further improvements
  • New: Built-in text editor. Text files on the server (txt, csv, cue, tag) can now be edited directly in RemotePLE - in the FTP tab as well as in the source lists. Open them by double-clicking, via the context menu "Edit file" or with Ctrl+E. When you save, the file is automatically uploaded back to the server. The character encoding (ANSI, UTF-8, UTF-16) is detected and preserved on saving. The editor is fully operable by keyboard and speech; while scrolling, the current line is read out. Text files also get their own icon in the lists.
  • New: Notification of new versions. If no automatic update is set up, RemotePLE can check online for a newer version at startup and show a notice. Can be turned on and off in the settings under "Advanced".
  • New: Speech on mouse movement. The announcement of hints under the mouse pointer now only reacts to actual mouse movement - a pointer left in place no longer repeats itself. Can now be disabled in the settings under "Speech".
  • New: Voicetracks recorded by RemotePLE can now be cutted in the Cue-Editor. Just set the "FadeIn" (F1) cuepoint as startpoint and maybe the "CueOut" (F10) cuepoint as endpoint for the voicetrack, then press Ctrl+B or the cut-button and after the confirmation, the file is shortened and uploaded back to the origin place. Cues and tags can not be saved for voicetracks in the Tag-Editor.
    (Lifetime for voictracks is normally just for on show, afterwards they will be deleted, so we dont want to spam the DB with entries obsolete in the near future) (Cue-/Tag-Editor is only available with configured SQL connection, open/close it by Ctrl+T).
Does anybody has suggestions for other/extended features? I'm just looking for getting more user feedback for optimizing RemotePLE, but a simple "works well for me" is also welcome;).
best regards
Roland
Version 1.0.0.124 is now available: Multiple root paths
  • New: Multiple root paths. The mapping between FTP paths and the drives on the RadioBOSS machine is now managed through a list on the
    "Common" tab. If your audio files are spread across several drives, you can add a separate mapping per drive.
    A single entry is still enough for the simple case; existing settings are migrated automatically.
  • Changed: The "SQL settings" tab is now called "RadioBOSS" and groups the RadioBOSS API, relay, trigger, livestream
    and database settings in one place.
  • Changed: In local mode (studio mode) the local paths are now entered in the "Local path" column of the root mapping;
    the FTP host field is no longer needed there.
  • since Version 1.0.0.123: Speech output improvements
    in the version notes, navigating now reads whole paragraphs at once instead of individual wrapped lines. This improves intonation;
    each bullet point is spoken as a complete sentence and decorative lines of equal signs are skipped.
    Special and punctuation characters can be announced by name when reading aloud, for example comma, semicolon or slash. Selectable in
    the settings under "Speech output": off, structural characters only, or all characters. Affects the internal text editor and the settings readout. In the text editor a short pause is inserted after each semicolon so data fields in CSV or cue files are easier to tell apart.
  • since Version 1.0.0.122: Now Playing (send the title to RadioBOSS API)
    RemotePLE can receive the title currently playing in a broadcast player (for example Traktor or Mixxx) and send it automatically to RadioBOSS as the cast title. This is useful when the sound is fed directly from a mixer into the sound card input of RadioBOSS, which otherwise knows no title. No extra Icecast service is needed - RemotePLE accepts the broadcast itself.
    Set it up in the settings under "Extended": port, on/off and the choice between the remote and the local RadioBOSS instance.
    The setting belongs to the current server profile.
best regards
Roland
Hello DJSoft Team, hello Dmitry,
I am currently adding support for listener song requests to RemotePLE.
It reads the queue with songrequestlist and inserts a chosen request either into a playlist that RemotePLE edits itself or into the on-air list, the latter through the API action inserttrack. That part works well.
There is one gap I would like to ask you about.
songrequestlist reports a played attribute, but there is no API action to set it. From testing on my own instance I see that RadioBOSS sets the flag when a request is dispatched from its own request window — even while playback is stopped — while an insert made through the API does not set it at all. So a request taken over by an external tool stays played="False" indefinitely, and there is no way to tell the server it has been handled.
At the moment I work around this with a list kept inside my application, but that memory is lost when the program restarts, and it is invisible to any other client or to a second operator working on the same station. A server-side flag would solve both.
Would you consider adding something like:
action=songrequestsetplayed&filename=<full path>
action=songrequestsetplayed&filename=<full path>&all=1
  • without all – marks the oldest matching entry as played
  • with all=1 – marks every entry with that filename as played
I would deliberately not add any further selector. Requests carry no id, so identity can only be formed from the filename, and a positional index would be unreliable: the list can change between the read and the write. Restricting it to "oldest match" and "all matches" keeps the behaviour predictable in every case. The all=1 variant matters when the same track has been requested several times with different greetings.
The existing songrequestclear already covers the "empty everything" case, so nothing further would be needed.
If you would rather solve it differently — for example by exposing a stable id per request in songrequestlist — that would work just as well for me, and it would make the API cleaner in the long run. Either way I would be glad to test an implementation.
Thank you very much for RadioBOSS and for keeping the API as open as it is. It is what makes a project like mine possible in the first place.
Best regards,
Roland
Each request has an "id" attribute to identify the requests. There's undocumented songrequestdelete command that you can use to delete individual requests - it takes a single id parameter. Perhaps you can use that to cross off the processed requests.
Thank you Dmitry, that's a perfect solution! So I just delete the handled request(s) and everything is fine.
I have already integrated it into RemotePLE and it works very well — thank you again for the great support!
One small observation in case it is useful: unlike the documented actions, songrequestdelete does not answer with OK or Error … but with the generic page <HTML><BODY><B>200 OK</B></BODY></HTML>. My first attempt therefore reported a failure although the request had been deleted correctly. I now re-read the list afterwards and compare the ids, so this is no problem for me — but a regular answer would make it possible to tell a successful delete from an unknown id. And of course the command deserves a line in the documentation, it is genuinely useful.
Best regards,
Roland
Hi Dmitry,
one more request, if I may.
RemotePLE controls RadioBOSS remotely, and I am building a wizard that composes scheduler action lines so the user does not have to type commands by hand. That works for most commands, but not for playlist generation: both generate <preset> and run PlaylistGeneratorPro.exe -preset=… need the preset name, and as far as I can see there is no way to find out which presets exist.
On my own machine the presets are files — …\Presets\PlGenPro\*.genprs, where the file name is the preset name. But reading them is not an option in a typical remote setup: our RadioBOSS machine is only reachable via RDP, and the file server is a different machine. So the names would have to come from RadioBOSS itself.
Would it be possible to add something like action=presetlist, returning the available Playlist Generator Pro preset names? The names alone would be enough, I do not need the contents.
And a small question about the existing syntax: the API documentation shows an example event with FileName="generate [pro] 1h". The [pro] marker does not appear in the scheduler command reference. Does it select Playlist Generator Pro instead of the built-in generator, and should it be used generally?
Best regards,
Roland
Yes, this is why it's not documented. RadioBOSS 7.2.3 now has this option documented, as well as "OK" response on success. To make it backwards compatible with older RadioBOSS versions, you should still treat any 200 status code as success.
Currently there's no way to get the preset list via the API, mostly because there's also no way to control the playlist generator from there at all. We'll add such APIs in the future, but currently I can't tell when it's going to happen.
This example comes from the older versions where the [pro] modifier existed. It does nothing in the recent versions.
Okay, perfect - thank You very much! :)
I don't want to create or modify presets remotely. A full API for the playlist generator would be far more than I ever asked for.
I just wanted to rebuild the wizard that RadioBOSS already has: when I add an event and use the wizard to create a playlist, it shows a list of the available presets to pick from. That list is all I need — nothing about the presets themselves, only their names, so the correct one can be put into the command line. RadioBOSS reads them out very quickly already.
So please consider a small action that just returns those names, for example as a JSON response — everything needed for it seems to exist in RadioBOSS in some form already.
Perfect - Thank You - great and quick support as allways!(y)
I understand, but when we introduce a public API it must make sense, and be complete, and usable in general. Just adding a command that lists presets for the playlist generator seems out of place and not tied to anything, without any clear usage part (apart from your case).
It may be added as a part of some other API like getting general information, where it would list all libraries and presets and things like this, but for now I can't tell if we'll add this.
That makes complete sense — thank you for taking the time to explain the reasoning rather than just saying no.
I'm not blocked by this at all: the upcoming version of my tool simply lets the user type the preset name, and that works fine in practice. It was a "nice to have", not a requirement.
And I think your second point is the more interesting one anyway. A general information request that lists libraries, presets and similar things would be far more useful to me than a preset list on its own — the library names in particular, since action=library needs a name that a remote tool has no way of knowing. So if that ever happens, it would be very welcome. No hurry from my side.
Thanks again for the consistently helpful support.
Best regards,
Roland
Yes, there's no way to get libraries list either, originally this API was added to complement the song request system, where the user knows library name in advance. More reason for the general "get info" API - noted for the future versions.
Hi All!
The new version 1.0.1.001 is now released: Event scheduler, wizards and many improvements
  • New: remote control of the event scheduler, opened with F9. The events of the RadioBOSS instance are listed with name, time, days, group and state. The scheduler as a whole can be switched on and off; individual events can be enabled and disabled, run immediately, skipped for their next scheduled start, deleted, created and edited.
  • New: before every write access RemotePLE automatically stores a backup of all events in the folder "Backups" next to the program. The button "From backup" writes single events or all of them back; events that have already been restored are recognised and skipped. Please note: the backup files may contain credentials in plain text and should therefore not be passed on.
  • New: week overview of the event scheduler. It shows the scheduled start times of one week either as a calendar with seven day columns or as one continuous list, optionally with the event colours assigned in RadioBOSS. If more than one event that claims the main playlist starts in the same minute, this is pointed out in the text.
  • New: command wizard for action lines. Instead of typing the command line by hand you pick the action from a list and fill in the matching fields; the finished line is shown below for checking and can still be edited as free text. Available in the event scheduler and via "Edit command" and "Insert command" in the playlist and the OnAir list.
  • New: generator wizard for the Playlist Generator Pro. Several presets are entered as a table with one row each: preset, count, start number and output file. If the counter is missing from the file name it is inserted on request, with the number of digits that matches the highest number.
  • New: placeholders in the file name for date, time, weekday and a time offset can be picked in both wizards from a button next to the respective field. Every entry states its meaning and today's value alongside the code.
  • New: file and directory selection on the server. Paths no longer have to be typed from memory. The selection works across all transfer modes - FTP, FTPS, SFTP and local - and converts the path into the notation of the RadioBOSS machine by itself.
  • New: song requests, opened with Ctrl+W. The request list of the RadioBOSS instance is shown with title, message, state and waiting time and can be inserted at four positions into the playlist or the OnAir list. The message is either read out or entered as a note. Single requests can be removed and new ones entered by hand.
  • New: send a whole playlist to RadioBOSS. Six entries in the menu of the FTP list do this: replace the contents of the edited playlist, insert before or after it, and replace the OnAir list, queue as next or append.
  • New: special entries are recognised in the playlist and the OnAir list and shown with their own icon: network stream, line input, time announcement, comment, hour marker, speech synthesis, teaser and container. When moving through the list the kind of entry is announced first, then name and directory.
  • New: the backspace key moves up one level in all directory lists. At the top level this is announced.
Since Version 1.0.0.125:
  • Brazilian Portuguese and Russian as additional program languages. The interface, help system and release notes are fully translated.
  • Settings: A missing trailing slash or backslash is now added automatically to the path fields when saving.
Latest (Beta-) Versions can be downloaded at https://buck-edv.de/apps/RemotePLE/ (the page is available in 7 languages)
Does anybody has suggestions for other/extended features? I'm just looking for getting more user feedback for optimizing RemotePLE, but a simple "works well for me" is also welcome ;) .
Best regards,
Roland
Hi Dmitry,
I'm trying using readtag / writetag to let my remote playlist editor work with track data over the API, as an alternative to a direct MySQL connection (useful for users whose database isn't reachable from outside).
I noticed that readtag doesn't return the Mix Start value, even though it's a regular field in the Track Tool and can be detected via makelibrary <mixstart:…>.
Looking closer, it seems to be a pattern rather than a single omission — the returned set covers the fields up to HookIn/HookOut, but not the ones that were apparently added to the track data later. Missing from the response (compared to what's stored per track):
  • Mix Start
  • Ramp
  • Dayparting
  • Gender
  • Language
  • Disable song
  • Start/end dates
Two questions:
Is this intentional, or simply not updated yet when those fields were introduced?
Does writetag accept a MixStart attribute if I include it in the XML, even though readtag doesn't return it? If so, the gap would only be on the reading side, and I could work around it.
For my use case, Mix Start is the important one: my editor shows ten cue points, and if the API can't read or write that one, a user could set it and lose it silently on save. I'd rather disable the field in API mode than risk that — but of course it would be better if it simply worked.
No urgency at all, I just want to know which way to build it.
Thanks and best regards,
Roland
We'll check this, maybe some fields are left out intentionally - I'll add this for the future improvements list for now.
