Not Broadcasting.
DJ Chris
Hi,
Is Icecast up and running today?
Keep getting this error: 17/08/2026 10:40:09
HTTP Request (#4: Now playing HTTP) error: Not Found
Any ideas where to correct this? Been broadcasting for ages now with no problems, but started up this morning n this is what I'm seeing.
I have Radio boss, and the HTTP notifications are disabled.
Is this any help?
The error message means that the notifications are enabled, and there's an error when sending it. Where do you see this error message? If in RadioBOSS software, then check configuration in Settings > Reports > Notifications. If in RadioBOSS Cloud then it's in Integrations >HTTP.
Thanks for your advice, it seems to be OK now.
Thanks for your time with my problem.
Excellent replies, as always.
Best wishes.
Chris.
