Using RadioBoss Cloud, I want to know what happens if the relay stream keeps buffering or stop: RadioBoss Cloud will keep trying to (re)connect even if in the events settings I've not set to repeat every XX minutes, etc?
Also, let's say I set to repeat every 1 hour: the relay stream will load/buffering again or will be kept without buffer, because it's already playing and the rule "repeat" just instruct that stream should keep playing?
The goal here is to keep the relay stream 24/7 playing and ensute that, even if relay stream got failures or buffer, RadioBoss Cloud will reconnect whenever stream is back online.
So, let me know the best settings to accomplish this. Thank you!
