radiodungog
Dimitry,
The Prelisten function is fantastic - and so too is the feature to listen to track after track automatically.
However, I just found an obscure bug.
Right window - Library Search
Right mouse click - Prelisten
Select - Next track after 4 seconds
The next track to come up is not in the Library Search list but instead in the Playlist tab to the left.
Obviously the Prelisten function would be best if it operated and continued to operate in the section it was started in.
Have you seen this before ?
It's also very good to have the up and down arrow buttons there all the time so it can be moved to the next song manually if the timer function is not required.
Thanks, Jamie C.
Thanks, Jamie C.
