Custom Hotkeys
JP_LEV
Hello :-)
I wanted to ask if it might be possible to use user defined hotkeys at some point?
So that I can control RadioBOSS with my programmable keyboard (PREHKeyTec).
Therefore, I would like to use the following key combination as an example: SHIFT+ALT GR+J
Kind regards
JP
You can configure hot keys from the Settings->Hot keys menu. Or do you mean you need global hot keys, the ones that work even when RadioBOSS is not focused/visible?
That's what I saw. However, I cannot store my defined hotkeys because the combination for the hotkey would be SHIFT+ALT GR+J. I have a programmable keyboard that uses this combination.
A global setting when radioBOSS is not in focus would also be great!
It will be possible to use key combinations in one of the future updates, thank you for the suggestion.
Global hot keys are also planned to be added in RadioBOSS 6.4.
