DSP 64bit for an old PC...
tieffeitalia
Hello...
I'm testing the new 64bit version of RadioBOSS but my favourite DSP (OctiMax) doesn't work at 64bit.
The machine is quite old... a Pentium 2Duo processor and the 64bit version of StereoTools can't run on it.....
Do you know of any lightweight DSP that works well at 64bit? Thanks.
If the plugin you need is only available in 32bit then you can simply use 32bit RadioBOSS. There's no practical difference between the two versions.
