line-in stops playing!
moh001
we have RadioBoass 5.2.3v, we have external usb audio adapter, we use its microphone input as a line-in, it works but sometimes it stops playing and we have to double click on it, so that it palys again. whats the problem? is it a bug in this version?, the electrcity sometimes fluctuates, i suspect this is why the app stops, how to force it to work automatically without us clicking on it again and again, help!
moh001
well, i found out the problem happens becuase the usb audio adapter sometimes disconnects, and reconnect, when this happens the radioboss has to be restarted to be able to play the line in again..
You can add line.in to the playlist and set it to repeat, in this case, if it fails to play, it will start the playback again. However, I'm not sure how it will handle device disconnection. It can detect such a situation sometimes, so putting line in on repeat should work.
