NestorC Active member Oct 19, 2023 #1 In the daily logs, the time appears as the first column. Could you also include the Date (which matches the file name)?
D djsoft Well-known member Staff member Oct 23, 2023 #2 You can right click the column header and add Date column from there.
NestorC Active member Oct 23, 2023 #3 djsoft said: You can right click the column header and add Date column from there. Click to expand... Hi, Yes... I know that, but I said to include the date field in the log file.
D djsoft Well-known member Staff member Oct 25, 2023 #4 NestorC said: Yes... I know that, but I said to include the date field in the log file. Click to expand... What is the point of this, given that file name already contains the date?
NestorC Active member Oct 25, 2023 #5 The point is that I combine all those log files into one, but I lose the date as it is not in any column.
D djsoft Well-known member Staff member Oct 27, 2023 #6 NestorC said: The point is that I combine all those log files into one, but I lose the date as it is not in any column. Click to expand... If this process is automated, you can probable add a column while files are combined. I'm afraid there's no value in adding it to RadioBOSS.
