No Icons RB 5.2.2.0
I had the worst experience with RadioBOSS in this morning.
I install it and surprise. No Icons in toolbar menu.
The problem is that right now I am in Live and I cannot uninstall it.
Unprofessional...
Windows XP SP3
UPS !
Find it !
In View -> Tool Bar
Now is very cool...
Very, very G(o)od experience with RadioBOSS  ;)
This is called "customizable user interface" :)
No way!
I can give you the playlist. In fact all playlists.
There is a problem in RadioBOSS at first start.
Just close and open didn't work.
I uninstalled it and reinstalled it and worked.
No way!
It looks like an answer for another topic? This one - http://www.djsoft.net/smf/index.php/topic,4164.0.html
Just checked it again, all playlists are opened as they should... I'd suggest you to check your PC for viruses.
No way!
Possible! I'll check it...
If this still happens, please create a video of this strange behavior, as we're not able to reproduce the bug here. I've also reviewed code changes between 5.2.1 and 5.2.2 and there's nothing which can lead to playlist loading errors (although it's possible that I've missed something).
