Pause Recordings in VT-Recorder
Jörg B
Hallo, i would like to see the feature to pause a recording in Voicetrack Recorder so that recording and pausing the recording can be toggled.
This doesn't seem to be requested much, so I'm not sure if we'll be adding such a feature. Voice Track editor allows you to delete portions of the recording, so you can remove unneeded parts after the recording is stopped.
OK, but it would make it much more accessible for those who use screenreader and Braille Display or have some motoric issues. Reading on a Braille display is not that overfiewing like on a screen. you often have to change the focus and if there are some infos to read in a textfile or a website for a voicetrack, it could be an advantage when there was a feature to pause the recording. In some case, screenreaders loose the focus and when that hapens during a voicetrack recording, it takes lots of time, to edit the voicetrack afterwards.
Thank you for the information. We'll see if other users also request such a feature, and then consider implementing it.
