Phantom folder
James@2YYY
A folder appears in my community radio station RadioBoss with the following file name C:Music/Theculture. It does not exist on the local C: drive. I have logged in as Admin to delete is but can not delete it from RadioBoss. How do I achieve this? A screenshot of the offending folder attached.
The folder is now empty in RadioBoss but is still viewable in the music library. It is not physically located on the C:Music/ tree. I can see no way to delete the folder from the RadioBoss library. Suggestions on a fix please?
When you delete files from the disk, it will not delete them from the library. You can update the library, or use Tools->Remove entries for non-existent files command to remove records for files that no longer on the disk.
You can also use Tools menu to create an event in RadioBOSS that will update library automatically for you.
