PLgenPro track repetition
Christian
Hi Dmitry,
  In the settings section is the "Do not repeat track" based on Artist and Title from file name including directory location or is it based on Artist and Title tag information?
This issue is that I have the same files in 2 different locations and I noticed that PlGenPro selected the same track but from the two different location with a 75 minutes interval. The "Do not repeat track" is setup at 240min.
Christian
The "Do not repeat track" is based on file location - it compares the file paths. If you have the same track in multiple folders, then you should use the Do not repeat artist and/or Do not repeat title options.
Good to know. Never knew that.
