This time I present an inconvenience that is generated with the autointro.
Disabling it by means of the command in the scheduler does not do so, it is not deactivated.
It does not enable or disable any. I have three rules programmed:
-Pisadores Normales
-Pisadores Vallenatos
-Pisadores Fin de semana.
Estos son los comandos que utilizo en el programador:
autointro enable pisadores normales
autointro disable Pisadores Normales
autointro enable pisadores fin de semana
autointro disable pisadores fin de semana
Just tried the commands you use and the rules are correctly enabled and disabled. Please check the AutoIntro list after running the command (you can use the Run Now button) - do you see the checkbox set and removed?
