radio caster
vangelis
Hello!!!
I use radiocaster latest version.
It works fine but titles metadata on player where i listeng i sawing every bit restaring and appears as much times as preview played track. Any solution?
A bid bad english.
Regards
I'm afraid I didn't understand the problem... Could you please provide more information, eg. screenshots?
Hello!!!
Isn't possible to show you a screenshot!!!
But titles for each track be played appearing as 4-5 times on player now onair:.
With Regards
Evangelos V. Katselos
OK, but where those titles do appear? When you play a stream?
What title source do you use in RadioCaster?
Hello!
I use radio automation ... and it export txt file on folder on local pc with automation with played track now onair.
I stream from another pc with caster yours software.
I give link through network for the now onait txt file. I used another streamer and dosen't make that problem.
I was testing some times.
Regards
Hello!
I already done!!!
With regards
Evangelos . Katselos
PS: Sorry, service not available. Try again later. Sorry, service not available. Try again later.
This message appears when ads are broadcast onair.
vangelis said:
Hello!
I already done!!!
I'm glad that problem is resolved now.
I don't think any of our products could produce an error message like this... Where did you see it?
Hello!!!
This appearing on txt file where i send you.
Do you publiced any new version for radiocaster?
With regards
I don't have any software to make any screenshot to show you on software. This message appears when adverisiments is going to be broadcasting. The automation is Jazler...
It looks like an issue with the software which produces the text file - RadioCaster just reads this file and uses its contents as a title.
i post a screenshot
I think you should configure the software you're using to broadcast so it produces a correct text file... I'm afraid I can't help you with it.
