Radio Caster, Custom encoders, is it possible to save as a file?
midzi
Hi,
I use Radio Caster for a few broadcasts per week, processed by Stereotool. I want to save them as processed .mp3 files for publishing. Is it possible to do this by making dummy encoders, streaming to nowhere and using custom encoders? If so, what parameters should I use? I am trying:
C:\Program Files (x86)\RadioCaster\Plugins\lame.exe -r -s {KSampleRate} -b {Bitrate} --resample {KSampleRate} - d:\path_to_some_folder\file.mp3
With no luck
Hi,
With no luck
You can record broadcasts using RadioLogger: https://www.djsoft.net/enu/radiologger_description.htm
If source of the music in RadioBOSS then you can use StreamArchive feature to record your broadcast or even downmix playlist to a file: https://manual.djsoft.net/radioboss/en/mixdown-playlist-to-file.htm
