Recording Error
conorjesu34
The message is: "stream recording: encoder exited with an error. Please check stream archive settings.
Then it records after 2-3 tries.
Now the problem is, the recording isn't going to the desktop like I have it set to go...
What RadioBOSS version do you use and what encoder settings? Try the standard like MP3 128kbps 44100 Hz stereo. Also ensure that recording path is correct. If it can't save the recorded files, it will show an error.
