After playing for 10 minutes, the overlay event will also stop. They may overlap in some cases, e.g. it can take couple of seconds to start the stream; if there were interruptions, it will be restarted which also takes time so effectively it can "run" for more than set time.
I've set a test to repeat a stream every 2 minutes and keep the duration 20sec -- but, after starting stream, 20 seconds after the stream it keeps playing...
This is FYI, I do not need to repeat stream every XXsec/min, but maybe at any point, this will be necessary. For now, maybe I am doing something wrong?
I did a quick test and overlay event with stream playing in it indeed closes after stream's playback time is up so there's no bug.
If you simply play the stream and nothing else, you can simply add it to the playlist. Main Playlist in RadioBOSS Cloud works in Repeat List mode meaning it will repeat over and over. If there's a single item, it will be repeated - meaning if the stream "ends" for whatever reason, it will be restarted, indefinitely.
The screenshot of my settings is that after the time set/duration the stream it keeps playing;
Not work for me to keep the stream 24/7 over the playlist.
I am currently using "overlay playback" with the stream URL 24/7 and I have two scheduled events with two triggers (10 seconds each) that are sent every 30 minutes (markers)... The key here is to keep the streaming running 24/7 and, every 30 minutes, send specific metadata (trigger) without interrupting the stream:
The stream works fine and is reliable, but if fails at any point, I would like RB Cloud it keeps trying until gets a connection... Maybe a featured request...
That's why I've requested if-> then featured
here and, of course, another great feature will be creating a playlist and, instead of interrupting the playlist to send a file with metadata, RB Cloud just sent the metadata in the scheduled time I set... For now, overlay stream + scheduled events is the only basic way I've found to accomplish the goal...
Any comments are appreciated. Thanks.
