Station ID Sweepers from Carts
HMMMM
I have noticed that when you set a cart to run over a song or at the end it doesnt push a Station break especially from the cart I also notice in my version if you set folder settings to uses the same track title it doesnt do this as the Station ID is over music . This also does the same thing if its placed into the playlist it uses its wave name even though the folder setting FileType > Use Custom Title format i.e ####### Break Station ID ####### should overide it can you assist please Dimiitri thank you .
The cart wall is a play on demand feature. You press a cart button, it plays a track. It doesn't suppose to start any other files. Or did I understand you wrong?
The cart wall item can't be inserted in the playlist. As for track titles, if you use RadioBOSS 6.0, there's a separate column - "Broadcasting title" that shows when title is sent to the server.
