StereoTool with RadioBoss
matteolop
yesterday I put StereoTools on my RadioBOSS x64Bit.
1) can you make sure it works fine and doesn't crash RadioBoss?
2) Can you tell me why it always goes on red RB?
What should I do to keep it from increasing?
Please,
Thank You Dimitry ;) (y)
I also use stereotool but on a 32 Bit Radioboss i have no problems at all
Windows 10 Enterprise 64-bit
CPU
Intel Core i5 750 @ 2.67GHz
Lynnfield 45nm Technologie
RAM
22,0GB Dual Kanal DDR3 @ 666MHz
Hi Patrick.
Thank you for your reply.
I list my features.
Do you think it could be good for making web-radio h24/7?
AMD Ryzen 5 3400GE
RAM 16,0 GB DDR4
SSD 512Gb
Windows 10 Pro
We didn't extensively test it, but in general, it works fine. Other customers use it and we don't see a lot of support requests about it.
StereoTool is loaded into RadioBOSS address space, so any CPU it uses (and, depending on configuration, StereoTool can use a lot) will be counted into RadioBOSS process usage.
Yes it works fine but make sure you downloads correct version as there are differences
