Mike Spencer
Good morning team. A technical consultation:
What is the ideal time for transmission reconnection? The default is "5". If set to "1", is there an overload problem?
The same question for the player buffer. In my case, placing "5" seconds leaves a very big bump before a cut of the live broadcast.
What is the ideal time to configure?
I would appreciate the prompt reply.
Best regards.
(In Spanish:
Buenos dias equipo. Una consulta t?cnica:
Cual es el tiempo ideal para la reconexi?n de la transmisi?n? Por defecto es "5". Si se configura en "1", hay alg?n problema de sobrecarga?
La misma pregunta para el b?ffer de los reproductores. En mi caso, colocarle "5" segundos deja un bache muy grande ante un corte de la emisi?n en vivo.
Cual es el tiempo ideal para configurar?
Agradecer?a la pronta respuesta.
Saludos cordiales.)
Best regards.
(In Spanish:
Saludos cordiales.)
