• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: RadioBOSS Cloud [beta]  (Read 93646 times)
0 Members and 2 Guests are viewing this topic.
  • Administrator
    • http://www.djsoft.net
Re: RadioBOSS Cloud [beta]
« Reply #360 on: January 27, 2020, 09:30:41 AM »
Any News about the possibility to upload Files straight from Google Drive? I mentioned this a year ago or so and you guys said that it would be a future development for Google Drive & Dropbox
Yes, this is planned for the future, but uploading files is already possible from the web browser or using FTP, so adding one more option to upload files is not that important at the moment, as there are other areas that has to be improved (like listener statistics).
Radio Radio
« Reply #361 on: January 27, 2020, 09:50:28 AM »
When My scheduler says that the item should run mo-sat but not on sunday, it kept repeating the message ALSO on Sunday. It has not done this before. See attached image for settings....
This event is configured correctly, but there is another event named "1STAT Wellness Sundays" that starts the same item on Sunday, it could be the cause.
At the time of writing this post, the logs indicate the "STAT Wellness Shorts" event indeed started on Sunday every 26 minutes, but it's hard to tell what was wrong - there's no event with such name now, and the one named "kSTAT Wellness Shorts" has different configuration that you posted on your screenshot and I suppose it was also configured differently on Sunday.
Guys, you are really trying to walk away from this one...As you know I have been a big supporter from day 1, always happy and things are great. But Now you try to make us look as fools as if we do not know what we are doing.
Yes the second kSTAT was generated to fix the issue. The first stat wasnt changed.
If this is the new policy to move the problem to (experienced) customers, you have to rethink your business model....
Im very annoyed with this... (we're making a living with your software....)
SertanejaPop
    • Sertaneja Pop
« Reply #362 on: January 27, 2020, 10:08:30 AM »
It looks like the track was added to the playlist by another event
Sorry, I already checked that out. There was actually another event being performed doing several repetitions, some of which I hadn't noticed. But thanks.
SertanejaPop
    • Sertaneja Pop
« Reply #363 on: January 27, 2020, 10:17:11 AM »
Already taking advantage, it would be good that this scheduler had the option to schedule hours and minutes too, as it is done for days of the week. This makes it easy to create ads for certain hours without having to create multiple ads. For example: I have an ad for 10, 11 and 15, 16 ... So I have to create an ad for 10 and 11 and another for 15 and 16. This could be done in just one, as it is done for the days of the week.
  • Administrator
« Reply #364 on: January 28, 2020, 09:31:53 AM »
I'm sorry for that, I think I was misunderstood. As you see, similar problem reported by SertanejaPop turned out as incorrect event configuration, and there was no bug in RB Cloud (however it still took fair amount of time to understand).
Invesatigating things like this is tricky and time consuming, that's why before diving into this, I have to be sure the event being checked is actually the one that was reported as faulty. In your case, event was renamed and, probably, modified (that was unknown at the time of writing previous reply), so I decided to collect more information about it.
Please reconfigure it to be one event (as it supposed to), check the days when you want to run it - we'll check how it's processed internally.
  • Administrator
« Reply #365 on: January 28, 2020, 09:32:39 AM »
Yes, this is the feature that is planned - "Multiple start times for event" that will do what you ask.
  • Administrator
« Reply #366 on: January 30, 2020, 12:55:12 PM »
RadioBOSS Cloud 0.8.0 beta
What's new
  • Improved screen reader accessibility in Media and Overview areas
  • Fixed folder drag-n-drop in Media area did not work properly
  • Fixed page reloading loop under certain circumstances
  • Fixed bug: certain file types were not included in Logs and Reports*
* In order for the fix to take effect, please open Settings and click the Save button
rllom
  • Diseñada Exclusivamente para Tus Oidos
    • Radio Andromedda
« Reply #367 on: January 30, 2020, 03:10:03 PM »
Excelent!!, when can edit title to files from url stream?
http://radioandromeda.tk - Combinación Perfecta del Pasado y El Presente
Radio Radio
« Reply #368 on: January 30, 2020, 11:51:57 PM »
OK, I'll reset it to how it was. In this case the scheduler has to run on sunday mornings, so I have to wait till sunday from 6-12 am to determine if the issue is still there.
See attached image. 1 active with sundays UNMARKED (and saved)
Other NOT active
thank you.
« Last Edit: January 30, 2020, 11:58:48 PM by WKOM Radio 101.7 FM »
  • Administrator
« Reply #369 on: January 31, 2020, 04:00:16 AM »
This is already possible to some degree:
* If you start network stream from the scheduler, you can enable the "Use event title as broadcasting title" option
* You can use the File Types feature (located in Settings), create a new file type and set "Also use file type for" - Network stream, set "Custom broadcasting title". This will set the title for all network streams. But if a title is specified with scheduler, it will have preference over file type title.
  • Administrator
« Reply #370 on: January 31, 2020, 04:10:37 AM »
Other NOT active
According to the settings, the event should not run on Sundays - we'll see if this is actually the case or if therer is a bug.
If you need this to run on Sundays too, you can enable the other event - as it is named differently, we'll be able to distinguish events in the logs.
The event in its current state will be tested, and if a bug confirms, a fix will be released shortly (before Sunday) :)
Radio Radio
« Reply #371 on: January 31, 2020, 12:58:51 PM »
Other NOT active
OK< the event should not play on Sunday's. This has been the same settings for a long time and suddenly changed last Sunday. The not active ws the fix.
Thnx
  • Administrator
« Reply #372 on: January 31, 2020, 01:54:40 PM »
I've put the your event event to our test environment and it was processed correctly - it did not run on Sunday. I think now we should wait for a real Sunday and see what happens.
Radio Radio
« Reply #373 on: February 02, 2020, 01:16:31 PM »
Issue is solved. For whatever reason everything is fine. Thnx
  • Administrator
« Reply #374 on: February 03, 2020, 01:51:58 AM »
Good - thank you for informing.
