On AIR Light
TODOPIC
Hello, it is possible to activate the microphone, activate the port pin, to turn on the air light...
Set/clear the value at the com-port out; out can be either dtr (pin 4) or txd (pin 3).
tanks!
Norberto
There are scheduler commands (set/get) that can control com port: https://manual.djsoft.net/radioboss/en/scheduler_commands.htm
Hi Dmitry
I have managed to control the ON AIR light using the SENT COM command and an arduino board.
Query, is it possible to insert commands using the Advertising Scheduler?
Tanks!!
Norberto
Ads scheduler is for ads only, but you can try inserting commands in intro or outro of the blocks (in the settings).
Hi dmitry
Thank you!!
It works by loading the send COM command in the playlist ... but its operation is not activated ... (if it does if I double click on it)
it's like it appears only in the listing, but it doesn't interpret it ...
works from CART, not from playlist ...
Thank you!
Norberto
FM ArcoIris - Firmat - Santa Fe
ARGENTINA
the commands inserted by the CART or by adding the ALt C command, appear in the playlist with a musical note icon, and are executed perfectly ...
The commands that appear loaded with advertising, the musical icon also has a clock ... they are not executed ...
tanks!!!
Norberto
ARGENTINA
They should be executed as well. Please try appending ".command" to the commands in the ads scheduler. E.g. "send com1 a" would become "send com1 a.command".
Hi Dmitri, now it works perfect!
Thank you!
Norberto Pellegrini
FM ArcoIris - Firmat, Santa Fe
ARGENTINA
