RadioBOSS 6.0 [beta]
Appears to be working here. Please ensure that it's actually turned on. You can adjust the Gain slider in the compressor settings, it's the most noticeable change (it controls playback volume).
Compressor working....Replay Gain still not working on new version 6.0.0.5
There are no confirmed cases when artist or other repeat protection rules do not function properly for Track List.
Well i posted a picture with it... it's confirmed, it just happens to me several times. Have you really checked your code? And i only use 2h separation using 8k songs. Could be misspelling, but i check everytime it happens and names are just the same.
Do you think i want to waste your time??? Not really, i just want my playlists to be accurate.
About differences in playcount by 20 to 0, you just act like it's ok. I don't agree... i really think it's serious and you should get more attention to it but this only my opinion which i think you don't care because i only use the "track list" option. It's about 3 years that i bring these questions to te table and they are exactly the same, with the same answer "it will be take in consideration in the next updates". Well, almost 3 years later i'm still here asking the same questions. That's why i didn't renew the licence and i had gave up on you until i recieved a mail from you a few weeks ago about experiencing the new update. Since it works just the same, this will be my last post. Call me when "track list" is acceptable, until then i'll work with a free software with similiar problems, but i don't have to pay for it.
Wish you the best
Esta dando erro em comandos quando inseridos na playlist. Apesar de aceitar o comando, a playlist congela e nao pula a faixa.
Segue abaixo mensagens de erro no log
Command: set autointro off
Unable to play! Error code 2 (unable to open the file/invalid server address).
If you add commands to the playlist, use the Playlist->Add command feature, and if you modify playlist manually using text editor, include .command after the actual command, e.g. set autointro off.command
You can reset the playcount: https://www.djsoft.net/community/threads/reset-playcount-in-radioboss.6299/ and an option to also clear Last Played will be added too in the future versions. The played history column will be added to the music library.
Thank you, it looks like track metadata is indeed wrong.
Currently it's a limitation, only one track can be dragged. If you need to move multiple tracks it could be better to use Cut/Paste features.
É exatamente assim que estou fazendo, como pode ver nos prints.
O comando "set autointro off" ele é obedecido, porem aparece o erro "Unable to play! Error code 2 (unable to open the file/invalid server address)." no log.
O comando "set repeat_track" além de não ser obedecido, ele trava a playlist. esta funcionando como se fosse um "stop".
O comando "stop" nao funciona na playlist auxiliar, nao importando a maneira usada para coloca-lo.
In the 6.0.0.5 update, the error in the "set autointro off / on" command was solved.
The "stop" command error in the auxiliary playlist persists.
The error of the command "set repeat_track" continues and now it is running infinitely, as you can see in the log.
When using the cartwall to loop a beat bed it will only play once. It will not loop even when checked.
Jingles/Sweepers are still fading in and out despite new setting for those files.
Finally found out. If you have an event with DTMF Start and End, and after that if there is a Event with checked "Clear playlist" or "Remove previous schedule" the DTMF End will not be executed!?
If the DTMF event is removed from the playlist, its "DTMF End" will not run because tracks are no longer present in the playlist.
Forgot to mention, it's a Event with playlist!
So the Playlist windows is not empty. The tracks are loaded in the Playlist and wait the DTMF End signal. But if in the Event (with tracks) are checked "Clear playlist" or "Remove previous schedule from the playlist" the DTMF End will not execute and the songs will not play?! Only if these two options are unchecked the tracks will play.
Good evening,
the song-on-demand system doesn't work with me. As I put SQL I changed the port but nothing works. Is this normal?
Why if we are in SQL we have in the discotheque XML databases
I also have problems with the "Voice Tracks" which cut before the end and very short "Hit Parade Number" audio files which do not play.
Under MySql the WMA files do not seem to be taken into account
Good night
Ciao,
Ecco cosa vedo nella schermata principale.
Il programma con la mia configurazione del colore impostata.
Non riesco più a vedere il giocatore.
E tutto un'immagine grigia.
gg2064 said:
It appears that mapped drives are completely ignored by Release 6. Will this be addressed?
This does not seem to reproduce here. It shows both shared network folders and network drives. They are available in the drop down list, or when you select "This PC" they will also appear in the main list. Please see the image attached.
Please review the following. Note the date and times. The first is from 5.9.4.0 and the second is from 6.0.0.4.
They are running on the same windows 10 pc. It shows that the mapped drive - MUSIC (\\WNAQ\WNAQ) (R) is listed in the 5.9.4.0 version and not in 6.0.0.4 version.
We can't reproduce it here. Can you please send one of the music tracks for which Replay Gain does not work to support@djsoft.net?
I meant for ALL tracks
It can also be done for all tracks using the procedure described in the link I've posted.
Is it possible to put it also in RB? In the "log" when selecting a song and then right clicking.
Thank you for the suggestion, we'll consider adding this.
It is OK because those 20 or even 20,000 playbacks could have been years ago and checking playcount is not relevant when selecting tracks. When checking for repeats, it processes the recently played tracks list and ensures that the newly selected track satisfies all the repeat protection rules - only compared to what was playing recently. Do you actually experience this in the latest 6.0.0.5 update, that repeat protection for Track List does not work? Do you see any error messages in the log like "Unable to selectg track"? If so, please send a screenshot of the Track List for which repeat protection fails, we'll try to reproduce it here.
Thank you, we'll see what could be wrong there.
Please put check marks for the settings you need to override. When there's no checkmark, it uses global (music) settings. We'll probably change this logic in the next update so perhaps you should just waut for it.
script error when trying to access the web.
The web browser component uses IE engine that is outdated and may not work properly with most modern web sites. Thank you for pointing out this issue.
Prelistening with the same soundcard problem still persists, muting playlist in prelisten window mutes also the prelistening sound
Yes, it's still in the queue to be fixed.
Starting dimming while mixing is what doesn't work
Can you please send a screenshot of your crossfade settings and specify more details about what's not working properly?
