RadioBOSS 6.0 [beta]
Good evening
I tested with IPV4, Msqlite, and Mysql and nothing worked.
I went back to version 5.9.4 and without changing anything it works
Good night
thank you for your message
No pad e error message
I will reinstall version 6, should I choose IPV4 or MySqlite better?
Give me more path for the "databaselog.txt" report, is it under RadioBoss or Windows
thanks in advance
In order to display this info, it reads the tag. If those fields are empty, either the tag is empty, or requested filename is wrong - e.g. file does not exist. A test does not confirm the bug - requested song info is shown in full here. Please check that the file name is correct.
This topic is about 6.0, not about older versions. Stream handling changed in 6.0, it uses a different approach to test the stream, but even with the previous version we did not see it sitting on a disconnected stream.
In this case stable OGG stream seems a much better choise than unstable FLAC stream :)
There's a separate column in the playlist "Broadcasting title" that will show the title you enter (this is also what is sent to the server).
Yes, it's good to check!
Thank you!
this was when doing a segue editor on the current tracked and a station id track which was next.
played track sometimes does not show playcount or last played info even though it WAS played, here atlanta rhythmn section track DID play but not updated whereas the donna summer summer is still playing right now and has already updated both fields
I'm not sure about IPV4 - there's no such ocnfiguration. And there's also no "MySqlite" database - there's MySQL and SQLite. If you don't need database to be available from multiple computers, SQLite is the best choise as it requires zero configuration.
Did this come from the Segue Editor or from RadioBOSS itself?
segue editor 3 does not show the 3rd track details
It seems that the 3rd track is in the right part, invisible, you can scrtoll to it.
How often does it happen?
thanks in advance
Hello
I made a mistake it's ID TAG sorry
I reinstall with ID TAG and the songs on demand does not work unlike version 5.9.4
Where can we find the log file you requested?
I reinstalled from zero with the latest version 6.0.0.9
and using SQLite
"SongRequest" still has the same concerns
and I believe that in the library the software does not take WMA files
Thank you
little limitation. with shoutcast AAC bitrate is always variable, despite the fast theses low consumtpion streams shouldn't goes over the bitrate we set. so CBR-VBR option on radioboss / radiocaster should be welcome.
when a sheduled even starts, media info section doesn't load and having a blank space. i just updated to 6.0.0.9
Two very, IMPORTANT problems:
  1. Playlist do not refresh after inserting tracks. That means that there is no time recalculation. Hard to create playlists.
  2. In Search tab duration is not accurate. In Version 5.7.2.0. it was perfect. Now it is not. That makes almost impossible to create perfect playlists.
It is related with this post.
Please solve this issues. Thanks a lot !
Playlist makes a refresh here after inserting tracks on 6.0.0.9
i forget one important point. when we touches the scroller on the right, playlist keeps scrolling like crazy even when mouseover is out of the scroll zone.
sorry for my ensglish skills
In previous messages you said that requested songs do not play. This is clearly because the requested song file name is not correct. And this is also the reason why it does not show tag information. We can't confirm this bug here, the song rerquests work as intended. The problem seems to be with your song request script, it supplies incorrect file name.
The bitrate is constant (CBR) with RadioBOSS. Using VBR bitrate for streaming is not recommended and is not typical.
Please ensure that you have enabled "Track information follows playback" option, and also that you don't edit the tag (in this case it will not update until the tag is either saved or changes discarded).
This does not confirm here. Do you use the latest beta?
NO ME DEJA EDITAR LOS METADATOS DE LA MUSICA
Please try restarting it.
Can you please provide some details? Scrolling seems to be working as it should here.
Hello
and using SQLite
Thank you
OK So according to you, with version 5.9.4, the script returns a correct filename but without changing anything this script returns an incorrect filename with version 6.0.0.9. No problem I will go back to version 5.9.4 and I will not update during the final version
It's just that we are unable to reproduce it here, also from code change history no changes were made to the song request system compared to 5.9.4 :) I suppose the problem is somewhere else. Tag reading is a result of other problem - when you play the requested file does it play or it shows an error? In case it's error 2 that means incorrect file name.
No, the artist and the title are not displayed in the "Title search" screen there is only Message and Requested. The titles of the different information in the database may have been changed, namely "ARTIST" to "ARTISTE" for example
BUG
RB 6 do not list right (correct) ascendent (or descendent) duration of the tracks (in Search).
- nothing happens on click view/scheduler (we have to use the scheduler inside the left panel)
- on tools/statistics text is blinking each second, which is really annoying
- when we have 4 mountpoints or stream formats, stats don't uses the 4 differents colors announced and only add the values in a single chart (whitch is fine anyway)
- on the general playlist view on the very left there is a clock icon, sometimes it disappears, not sur is there is a checkbox to show/hide it.
- on work zone, embedded web browser is internet explorer, no matter the defaut web browser of the machine
keep up the good work !
michael,
housestationlive.com
ps : just for your record, I have a celeron J3160, but CPU and RAM looks far from saturation
the machine works 24/7, it's fanless, so it can't be a performance destructor
plus, i have several others apps running on it, like shoutcast, nginx, obs, voicechanger, radiomatisme, radiocaster
cpu is 45° with approximativly 50 to 60% of memory and cpu usage.
unfortunatly windows 10 is a very big system consuming a lot (windows defender and windows antimalware sometimes just overuses capacities and almost no way to kill completely theses processes)
