disconnects every day
vanilla
hi , i have installed on the same pc 6 times the RB , everyday when the listeners going more of 3000 on one of my channels i have disconnections for a sec or two !
can you please advise ?
I have installed different versions of RB 5.7.2.0 , 5.8.5.2 but nothing changes , my internet connection its with 200mbs with 20 upload .
how can i be sure ? from server side everything looks ok , no disconnections or downtime ! any suggestions ?
RadioBOSS never disconnects unless instructed to do so (e.g. you turn off broadcasting). So if unexpected disconnect happens, the cause is external to RadioBOSS - it's either connectivity failurie or something to do with the server. You say that it disconnects when it reaches 3000 listeners - this means it's likely that the server is overloaded and disconnects. You should inspect server logs to see what's wrong there.
thanks !
