TBN Radio
Kindly look in to adding More Audio Processing for RBC, The Normalization is Not 100% accurate, Came across songs which are still sounding low and some which are loud even after applying the Normalization. It is bit difficult to manually adjust them as There are so Many tracks that are to be adjust.
More Audio Processing Might fix The Issue. It will be good if such processing will be added to RBC
