More Audio Processing For Radio Boss Cloud
TBN Radio
Kindly look in to adding More Audio Processing for RBC, The Normalization is Not 100% accurate, Came across songs which are still sounding low and some which are loud even after applying the Normalization. It is bit difficult to manually adjust them as There are so Many tracks that are to be adjust.
More Audio Processing Might fix The Issue. It will be good if such processing will be added to RBC
It uses EBUR128 algorithm to detect loudness, it's one of the best out there. You can manually adjust the level for each track from the tag editor (in Media).
TBN Radio
Ya, i have tried that as well, But when it comes to adjusting it Manually it’s quite a lot of files that are to be adjusted & finding out what’s the exact db amount for the tracks is another issue.
If Stereo Tool or Something Similar could be added to RBC it will be perfect
That either means that the normalization algorithm doesn't work for your tracks for some reason... Or if you feel that all tracks sound lower then you can simply adjust the target level.
I don't think this will happen, there are both licensing and technical issues. For instance, StereoTool requires lots of CPU to operate that will mean accounts with this option will be a lot more expensive.
In Media you can select the file and press the Tag Editor button to change the track parameters, including playback level.
DJboutit
Here are few free EQ VST plugins you can try out with Radioboss
7Q
Overtone GEQ
CompEQ
Broadcast - This one was designed for internet radio stations in mind
Voxengo Marvel GEQ
Stardust - I have used this one and it is decent
I am currently using Stereo Tool is good settings
