sakda.bumroongtin Member Jan 28, 2022 #1 Dear Support, Ok, I try to do by you instuction Toos / Prcess music tracks / BMP a lot of file not show BMP Could you please help? Thank for advance. Attachments radioboss.jpg 110.6 KB · Views: 292
D djsoft Well-known member Staff member Jan 30, 2022 #2 sakda.bumroongtin said: a lot of file not show BMP Click to expand... It means that RadioBOSS was unable to automatically detect BPM value. You can open file properties and set the value manually.
sakda.bumroongtin Member Jan 31, 2022 #3 have anyway to automatically detect BPM not set set the value manually? or use 3rd party software to update?
D djsoft Well-known member Staff member Feb 2, 2022 #4 sakda.bumroongtin said: have anyway to automatically detect BPM not set set the value manually? or use 3rd party software to update? Click to expand... RadioBOSS automatically detects BPM when it's able to, otherwise it will give a -1 result.
