RadioBOSS 6.3 [beta]
Esto es lo que sucede aquí, si se inicia el desvanecimiento, continuará después de que comience la siguiente pista; no se corta ninguna pista. ¿Usas la última actualización? También puede intentar usar el comando "siguiente" en su lugar.
Parece que la operación llevó mucho tiempo, por lo que se consideró congelada. Se arreglará, gracias.
Yes 6.3.0.4.
La pista se vuelve a reproducir si se reproduce otra pista en la lista de reproducción. Cuando le muestre qué pista seleccionó, se reproducirá si es la siguiente pista, pero en caso de que haya reproducido algo más en la lista de reproducción, la pista cambiará.
the playlist comes out alone as chosen by the RB. The random folder is broadcasting the tracks, but it announces that it is going to come out, for example, POLIMA WETCOAST, and yet when it is time to play it changes to a different one, FABBIO. You can see it in the images. This was already fixed and it has happened again.
For which we work with the playlist with RB and random folders is important.
You see how bad it happens if the announcer announces that a song is on the air, however, when playing another song, it appears... Apparently this has reappeared after solving the error that RB repeated artists and you have touched this. Review it please.
Hi. Thank you for allowing me to participate in this forum.
The .wav files do not show the artwork, but the same file is converted to another format if it does.
greetings.
Here is the problem of the teaser closing cut when the following is a container.
The same tracks (which are file type) and only cut the end of the teaser, when they are in a container.
Two videos, with and without a container to show the difference. I also attached the audio at the end of the teaser to make it clearer.
Can you please provide more information on this bug? I'm not sure I understand what's not working right here.
Yes 6.3.0.4.
This doesn't seem to confirm here, can you please provide more details in what sequence tracks start and when fadeout command is run?
I see it plays track #6, you check what's going to play for track #8. But in between, track #7 plays, and that invalidates track selection for track #8 because it needs to re-check the repeat protection rules and select a different track. If we let selected track stay while other tracks play in between, there's a good chance that tracks/artists will be repeated. So, currently it works as intended. If you select Track List item, any in the playlist, it will show what track is selected there for playback. If this will be playing next (manually, or you set a queue for it) - the shown track will play. When something else plays, a new track is selected there to ensure repeat protection rules are fulfilled.
Bug: With On Schedule option disable, every time RB starts, the control always appears enable, even though it is disabled
Version: 6.3.0.5 x64
1681048316037-png.13041
Now I can move neatly through the categories in the Playlist generator. I still cannot select a task with the arrows when only one task has been created. Two or more tasks must be created in the scheduler in order for me to select one of them. Best regards.
RadioBOSS 6.3.0.5 beta
Changes
  • Advanced option: ignore Outro point when processing voice tracks
  • Optimized deleting music files from library when many tracks are selected
  • Shows track duration in Track Tool
  • Fixed bugs
x86 https://dl.djsoft.net/beta/radioboss_beta_6.3.0.5.exe (4/11/2023, 33MB)
x64 https://dl.djsoft.net/beta/radioboss_beta_6.3.0.5_x64.exe (4/11/2023, 37MB)
With this latest update, the super since event that we use to put time signals, for example, now works correctly. that is, now if I see the fade in & fade out working correctly in the overlapped playback -------> configuration ---> configuration ---> properties ----> Event scheduler ----> by setting everything to zero , it works without fading correctly. Remember that before there was a mistake since it did not follow this route, it took the general one as if it were music.
Perfect problem solved DIMITRI. Great job.
We continue with other topics. We are informing you.
ALL THE BEST
Changes
  • Fixed bugs
Hello again Dimitri.
I pass a new capture of version 6.3.0.5 where the problem that announces that a song is going to be broadcast and a different one comes out. I have only left the program running and later it does it again. Check this to be able to solve. This worked fine in previous beta versions when this didn't happen, but there was an artist repeat bug. Thank you.
No estoy seguro de que los archivos .wav admitan obras de arte. ¿Puede enviar su archivo aquí ( support@djsoft.net ) para probarlo?
es posible que el archivo wav no admita el envío de carátulas a radioboss o cualquier otro como winamp, etc. Lo he intentado y tengo el archivo wav con su carátula pero radioboss o cualquier otra persona NO lo muestra
I have checked mine and it works fine. The only thing when deactivated in options, the programmer does not cancel the V marking, but if you look the color is weaker indicating deactivated. The correct thing would be for V activated to disappear instead of lowering the intensity so as not to be misled. Is that what truth means, that the mark disappears?
Delete my previous comment to this problem.
I made a mistake. I update my answer again because I can't edit. Nestor is right.
I have checked mine and there is a failure as NESTOR says.
Being deactivated in options, the programmer does not cancel the V mark, if the color is weaker indicating deactivated but it is false.
The correct thing would be that the V activated and event scheduler deactivated disappear, and this does not only lower the intensity of the activated color.
I have a teaser with opening, transition and closing.
When the teaser is followed by a container, part of the teaser is cut off. The teaser closing file does not play, (it is the audio file that I attached separately).
In the video comparison you can hear how that part of the teaser is not in the video that after the teaser there is this container.
I think the problem has to do with the mixing point or something like that. But it's just my assumption
Dimitri Beta testing
Version
: 6.3.0.5 x64 beta
Affected version: RadioBoss Retail and Radio Boss beta
Severity: Compromises product component use giving unusual errors on added components more firefighting.
Background : Dimitri informed us that he was firefighting the updates which was giving no time to add changes we wanted 1-7 We like this new update but think we have discovered the reason you are firefighting. We understand your issue and hope to help.
To Replicate: Firstly, back up your settings on Menu: Settings >>Settings Back Up & Restore >> Backup Settings . In the dialog choose a name directory and press 'Save button'. Quit Radioboss.
1) The next step often occurs if you update O/S get corruption in your computer profile or generally add a user. We need to change the computer name and current user the easiest way to do this is through the Windows operating system. Restart the computer and sign in with different user.
2) Open up Radio Boss and it will automatically restore from the backup which was a great add back in the day.
3) Goto the opened beta and choose scheduler and press 'on' the checkbox.
4) From the Menu : Tools>> Ads Schedular . On the dialog press 'Create Playlist and Events' button this error will appear :
Or similar with your old profile. It is notable that the new Menu Settings >>Settings Folder opens the correct roaming profile. However ,this difference is notable. It is believed that the back is recoding this old computer roaming profile and placing it in Radioboss. By this way much of the data in the Roaming profile is not available to RadioBoss and fictionality is reduce to bare minimum. This is serious issue . s currently we have found no way to remove this old data.
I hope this helpful Dimitri to move things forwards best wishes. You should also note the 'Sweeper track repeat' is missing from this beta it used to live on the View Menu. Also the audio track did insert but there seems not control on the volume or what was added. There is a volume set to 75 but this tracks volumes are all set in file types.
Can you confirm that due to the lack of an 'auto intro' route and 'inset wav' separate to the main music field we will be unable to use radioboss with a dsp and use these announcements until next year?
It doesn't reproduce here... Also on your screenshot it's version 6.3.0.4 :)
Looks like it's a bug with the control. I suggest having some "dummy" event created, or, set Group for the one event, it will make essentially two items in the events list and should fix the issue.
Yes, it was fixed in the .5 update.
This is not a bug, please see my explanation above: https://www.djsoft.net/community/threads/radioboss-6-3-beta.11183/post-45357
Please send one of such .wav files to support@djsoft.net to test.
It sets the control state to "Disabled" and this is how disabled looks in Windows.
Thank you for the details! Even if it's the mix point it still should continue playing together with the next track (container).
It will not cancel it. The scheduler state will be frozen in whatever state it was left when you disabled the "Scheduler" control. If it was on, it will stay on, and same for off.
