4K screen resolution issue
JeanXeb
Hi,
Already present in radioboss 6.2 then in 6.3 on my 4k screen, the software is struggling to follow the responsive, which makes using the software impossible.
Would it be possible to make a correction ?
(Restarting the software does not fix the problem.)
Best regards,
Please open Settings, View, Style, select one of the predefined styles - this should fix it.
I have the same Issue switching between a 4K screen and a Full Hd screen, really annoying. :'(
have a good day
The only potential problem is when you drag RadioBOSS window between screens with different DPI, this leads to re-scaling of the window and sometimes (due to bugs in the UI library RadioBOSS uses) it's not performed correctly. But if RadioBOSS stays on one screen (at least, its main window) there are no problems, 4K or not.
Yes in Exactly the probleme with me because I use a Full HD screen and I use Remote Desktop sometimes with my another computer to control RB.
Have a good day
You really understand this pairing device
Hi, There is an idea to correct this bug ? I'm using sometimes a 2K screen and sometimes a Full HD screen, and every time I have problems with that.
I'm using the fix with styles changes but it's really annoying.
Thank You
RadioBOSS works fine on 4K/any other hi-DPI screens, but looks like it poorly handles DPI changes. Mostly this problem lies in the libraries it uses to build the UI, so once they are updated, this will also be fixed in RadioBOSS. We'll also see what we can do about it.
Hi Dmitri,
I understand perfectly, that's why I like RadioBoss too, because it is really light for the same reason you are using Windows libraries. If you could find a way to use the newest libraries or to correct this UI bug, it could be reaaaallly nice.
Best, Thank you in advance
