LED Bars VU meter
Mixnetwork
Hi,
I would like to see the VU meters, but they only show up with the scheduler together, is it possible to activate the VU meter without the scheduler?
The scheduler I have in a separate window.
It's not on the scheduler tab, it's on the DSP tab. You can make it always visible from the View menu, "Mic and VY meter in the center" command.
I understand but I only want to show the led bars, now I see also Scheduler hoe do I separate this like picture?
So I only want to have the LED Bars
Like this, of course the black field in the right picture should not be there, I just did a cut in the Picture at the left
maybe you could make it so that the area where the log, microphone, the led and the scheduler and dsp etc could be moved or minimized so that only the led and the microphone remain visible
vielleicht könnte man es so machen das man den bereich wo das log, mikrofon, die led und den planer und dsp usw soweit verschieben bzw minimieren könnte das nur die led und das mikrofon sichtbar bleiben
That is a possibillty, not perfect but anyway.
Das wäre schon möglich nicht perfekt aber ein option
There are different tabs, if you don't want scheduler, you can switch to another tab. The whole left panel can be hidden, but this will also hide VU meter.
In the future versions, we'll add more options for VU meter location.
