How to play a syndicated show - with track metadata?
ok you're right, the .cue file contains the titles of the individual tracks but if I want to send this recording only the date appears in the playlist and not the titles,
In the playlist it will show information from tags (or extract title from filename if there's no tag) but during playback, it will use titles from the .cue file - you will see that title in the Nowplaying bar and also those titles will be sent to the streaming server.
Also, the radio listers still reporting is substantially wrong information. also, the Scheduler does not report correct information on random play it says it's not enabled when it is enabled, I think it does the same when you right click track add to Add to Playback Que:
Starting event "STATION BREAK - Hush DJ Denise Speaks"
Event was not started because the "Do not action when there are scheduled tracks in the playlist" flag is enabled (STATION BREAK - Hush DJ Denise Speaks)
Hope this helps
How to stop track 11 remaining.
https://gyazo.com/434d276cc12e2e8a56485038b86d2acf
1) As when the random pays it can pick up the same track 11 again as its not removed. right click 'Add to Playback'
2) As original Play from Log does not play.
[10] ABRA - Cry Baby
Schedule: [STATION BREAK - Hush DJ Denise Speaks] Hello I am Dj Denise - Am So Happy to play Some of My Music for You.mp3 (C:\My Music\Voices\Hello I am Dj Denise - Am So Happy to play Some of My Music for You.mp3)
[28] All Them Witches - Effervescent
It doesn't play the scheduled track at all and goes directly to track 28 added by right click 'Add to Playback' .
Hope this helps
Dimitri can you use this as a playlist live recording in the scheduler to schedule this pre played wave with cue file providing titles?
If you add a track to the playback queue, it will play next, queue has priority when next track is considered.
You can start a track that has corresponding .cue file - RadioBOSS will read it and show track titles from there.
What RadioBOSS version do you use? Maybe it's an older one, where .cue support is not added yet.
There is a single .cue file for the whole recording, it contains titles of all the tracks included in there. It's a text file - you can open it with Notepad to check its contents.
I need to check my forum notifications. I didn't realize this thread was getting responses.
Does the cue file have to include the timing info or can it just be a playlist with artist - title ??
I put messages on social media looking for LIVE or syndicated shows and 99% are syndicated. No one - I mean, NO ONE creates cue files! So, at least in the U.S., I cannot stream these syndicated shows.
sorry if I insist on this topic but with the rough Google translation it is not easy to understand. I did this test: I recorded three songs with rb which in playlist and streaming give me titles and artist, the cue file with the titles is present however if in a new playlist with the add file function I add this recording it does not show me the cue file and only the title of the recording appears in the playlist and not the titles of the 3 tracks. I hope I have explained myself.
.cue file is not a playlist, it has a special format.
If a show is a single file, in order to get individual track titles in the mix, you'd need to have a .cue file. Or it has to be a format that supports multiple titles during playback e.g. chained ogg file - but that's not supported by RadioBOSS (it will only read the first title).
By any chance does anyone manage or have managed to read the music tags coming from the mic-line? In practice, if I send music in flac with the mic function, input from mixer and microphones obviously radioboss has no way of reading anything, have you succeeded?
There's no metadata for the microphone. If you play linear input from the playlist https://manual.djsoft.net/radioboss/en/working_with_linear_input.htm - you can assign broadcasting title for it.
ok you're right, the .cue file contains the titles of the individual tracks but if I want to send this recording in the playlist only the date appears and not the titles of the individual songs
When you play a track that also has .cue file, RadioBOSS will display individual track titles from the .cue file.
ok you're right, the .cue file contains the titles of the individual tracks but if I want to send this recording in the playlist only the date appears and not the titles, I attach an example
This information is only available during playback, because information in the .cue file is tied to playback position.
