Teaser Error
matteolop
Hi, I use version 7.0.8 and I have a problem with the Teasers.
It basically doesn't play the choruses (starts from the starting point of the song and I already activated "AutoHook") and often skips forward after the first of the 5 teaser tracks.
As you can see, I set it to play 5 tracks in order with "AutoHook" for a maximum of 15 seconds.
But sometimes it doesn't do it.. I don't know why, but I know it's annoying.
Because the same thing works on another PC with the same version.
Sometimes it doesn't even play in order, but randomly.
And before, after the first 15-second track it switched to the Closing Jingle v2, instead of playing the other 4.
Do you know why it happens?
I don't think that's true, there were two hours of music in the playlist, and the songs don't have file types, so it can't ignore them
It doesn't check the entire playlist until the end. There's an option in the Teaser where you set how many track to look ahead.
Yes, I know thanks. I gave it 20 tracks in order mode. But it doesn't do it, it behaves badly and after a few seconds of playback it skips and gives me error 902.
(If you want I can make videos)
Thank you
Error 902 can appear in two cases:
  • Before a teaser starts playing, when it's clear that there are not enough tracks.
  • During playback, when it had build a track list for the teaser, but failed to load one of those tracks (e.g. there was a track in the playlist that teaser wanted to use, but it's unplayable for some reason).
