Web browser in RadioBOSS
Web browser tab in RadioBOSS uses Edge as a rendering engine. Typically, no additional configuration is required and the web browser works out of the box.
If, for some reason, the browser doesn't work, please install WebView2 Runtime:
Use the "Evergreen Standalone Installer" option, select x86 or x64 - must be the same architecture as your RadioBOSS installation. You can check RadioBOSS architecture by clicking Help->About, if it says at the top "RadioBOSS a.b.c.d x64" then you have a 64-bit version, otherwise it's x86.
If you do the two steps listed in the first message, RadioBOSS will use Edge as browsing engine automatically.
It worked for me with "RadioBOSS_ChromeWebBrowser" but after clicking the above link, Edge automatically installed without asking location.
Honestly not working for me even after uninstalling explorer and re-installing edge.
From your screenshot it seems that it actually works. The web address you input is not valid. Try https://gmail.com instead. The web browser in RadioBOSS is very simple, it won't add ".com" to the addresses automatically like the normal web browsers do :)
Thanks, it worked but after entering my email address, an error message appeared, see screenshot attached.
Witam
Zauważyłem, że przeglądarka WebView2 w RadioBOSS zapamiętuje login, ale nie zapisuje hasła. Dla użytkowników z wieloma kontami staje się to dość niewygodne.
Czy byłoby możliwe włączenie obsługi IsPasswordAutosaveEnabled lub zaimplementowanie podobnej funkcji, aby umożliwić zapisywanie haseł?
Z góry dziękuję za rozważenie tego — znacznie poprawiłoby to użyteczność.
Witam
Please write in English.
I've noticed that the WebView2 browser in RadioBOSS remembers usernames but does not save passwords. For users managing multiple accounts, this can become quite inconvenient.
Would it be possible to enable the IsPasswordAutosaveEnabled feature or implement a similar functionality to allow password saving? This enhancement would greatly improve usability and streamline the login process for many users.
Thank you very much for considering this request.
Thank you for the suggestion, this will be implemented in the next minor update.
