Advanced option to disable ctrl + shift + del a track and permanently delete from disk
Bjorn
We have a lot of oldies that like pressing random keys on the keyboard and they accidentally managed to delete some files from disk. Any chance we can have an option to disable this?
For now we've disabled delete permission within the windows folder permissions.
Cheers!
Hot key to delete files from the disk is Ctrl+Shift+Del - I don't think it can be pressed accidentally. I don't think there's a reason to disable it in RadioBOSS or add it as an option, in this case a reliable solution is as you did, configure folder permissions to prevent any modifications.
