access violated on event creation
matteolop
Hi, I was adding audio to the event I was creating for Christmas, and when I tapped the + button to add audio, RadioBOSS crashed and didn't restart automatically.
After doing it manually, this red warning appeared.
What could it be?
I'm using the latest version and haven't received a bug report to submit.
How do I send logs?
Thanks, I'm waiting for your feedback.
The crash in windows.starage.dll - looks like it's OneDrive or something similar that crashed. If it was one-off error, I think it should be ignored. If it happens often, please click Help-Contact Support-Send bug reports, we'll check what's wrong there.
This is odd, as the log (red line) indicates that the bug report was saved.
I know, I've always thought the same thing. But believe me: as soon as it crashed, I reopened it and the first thing I did was check for bugs to report. But nothing, it's empty. Where can I find logs or other types of files for you to analyze? I can't add anything else to my problem.
Another thing: why doesn't the RadioBOSS restart automatically? I enabled the appropriate option in the settings. Imagine if no one had been at the PC... would the radio have remained muted? :cry:
Hi, I know this isn't the right place, but speaking of bugs, I just discovered that if I try to open Playlist Generator Pro from the desktop (I created the shortcut) and don't launch it from within RadioBOSS, it doesn't start, it tries to open, and then closes.
Music Library, however, works and opens correctly.
If there's no bugreport, I'm afraid there's nothing else that would help us investigate this.
With this option enabled, it will restart on fatal error (the Access Violation error you get is one of those). I just did a quick test on the latest version, and it does restart on such errors.
In your case, maybe it was so severe, it was unable to create a bug report even. But it still should restart, as watchdog will detect it's crashed.
If you have user accounts enabled then the Playlist Generator can only be started from withing RadioBOSS.
I waited about 30 seconds and it didn't.
I manually started RadioBOSS after the fatal crash.
If this happens again, please write here, so we can investigate it.
Yes, it is, even with limited permissions.
And why is this possible with Music Library and not with Playlist Generator?
I'm not sure why it's like this, honestly. Do you have a need to run the Playlist Generator separately?
